I have a set of enkei rs rims laying around from my MZ20 and what do you know,they fit..... well sort of. The front rims fit on all hubs, but the rear rims have a smaller inner circle for the hub (does that make sense ?). Also the front rims are 8" and rear rims 9", any legal problems there ?
I like the look the enkei's give it, but want to know if it is worth the $$ to get the rims machined out.
heres a comparo
https://www.sau.com.au/forums/topic/257653-interested-in-opinions/
Take a search for Stagea and wheels.... I think you'll find the car wants identical rolling diameter AND footprint all around, otherwise the ATTESSA system can throw a tantrum. Anyone? I know they want the rolling diameter to be the same, but I'm pretty sure I've read about the width thing before. There must be a reason that all 4 wheels on a GTR are exactly the same size/width...
i like the ones in the bottom pic, they fill the guards better. also i think getting the rims machined to suit seems like a whole lot of effort.
as for the tire width. if you think about it, a 235 wide tire on an 8" rim will have a different fitted shape to a 235 tire on a 9" rim, this could reduce the rolling diameter, probably not by much, but it maybe enough to mess with the ATTESA. its just safer to rim equal width and size rims.
you can have different width rims front to back with ATTESA no worries at all. can have different offsets too
what you do need is an equal rolling diameter between the fronts and rears (left to right too, naturally)
you are correct in saying that a given tyre with a given width and profile will have a different overall rolling diameter if it is fitted to rims of differing widths due to sidewall angle. however, ATTESA has some le-way in it's design - it allows for the difference between a brand new tyre rolling diameter and a warn one and also allows different brands of tyres to be fitted front to rear (believe it or not, not all 235/40/18's fit the same due to sidewall construction etc) but i digress
i have always had a soft spot for the enkeis but i'm a sucker for good fitment (or at least better) so will say the second set as they 'fill' the guards more :(
thanks for the replies guys. you have all put my mind at ease now :( you are right about the guard filling issue. even the 18" rims look like 16" on a stag.
thats a nice wheel there RBPOWA
question #2
i would like my wheels to come out to the guards more. some have recommended +20 spacers. are they illegal ? do they shorten wheel bearing life ?
thanks for all the info, very much appreciated.
Jez
spacers are not responsible for any loss of life of wheel bearings any more than lower offset is - they both do the same thing by making the wheel stick out more. i doubt the wear on the bearings (if any) would be enough for you to EVER notice
i believe spacers are seen to be illegal (?) however if you do choose to get some make sure that they are hubcentric bolt on as these transfer the load through the hub and not the studs!
it's hard to tell from any pics you've shown us to determine what width spacers you would want and you've not told us where exactly you would like your wheels to come out to.. so the easiest thing for you to do is grab a ruler or a tape measure, hold it against the edge of your wheel and measure how much further you want it to 'poke'. that's the width spacer you will want. keep in mind i think (from memory) 27mm is needed to meet the length of the standard wheel studs - if your wheels don't have pockets in the back for the studs standard studs to protrude into once you have a spacer bolted to the hub then you'll need 27mm spacers minimum or to shorten the studs in your hub (which i wouldn't recommend incase you want to ever remove the spacers without needing to replace the studs)
on the other hand, if you are looking for new wheels pm me (or for any other wheel related advice) and i'll be more than happy to help you find something you're after :(
so are you saying that i could have got 245's or 255's on the rear and 235's on the front? and it wouldnt put the attesa out (note - i have 18x8's all round..)
if so thats sooooo gay... cos the guys actually were going to give to wider tyres on the back for the same price... :(:);)
i don't know the exact dynamics of the system but you can get away with slighty different tyre sizes... i wouldn't want to puch my luck though - just get the same all round. i've seen a number of gt-r's in japan running staggered sets without problems so it can be done although one would think they put plenty of thought into it first.
i wouldn't ever recommend a 255 on an 8" wide rim either
In NZ spacers can be legal if they are machined to support the wheel like the hub does (i.e. nut just hanging off the studs).
Regarding different wheel sizes people sometimes have different profiles to acheive the same rolling radius e.g. 9in with 265/35/18 on the back (=static radius 301mm) and 8in with 235/40/18 on the front (= 301) but a good tyre spec sheet will also show the loaded and dynamic radius which shows that they behave differently under load while driving. This may still be OK for the Atessa but I myself will use only the same width tyres front and rear - and after all wider rear tyres only really make sense for rear drive only cars.
ps I find this new way of listings posts a pain in the arts.
thanks for all the help guys, so very informative can't thank you enough. i think i will forget about the spacer idea too then ! i want my car to be as legal as possible.
I don't really think the wheels can come out that much further any way due to how low it is. It looks like it will start scrubbing on things. It needs to stay practical for daily driver too so no crazy -camber wanted lol.
My car is running 18x8.5 with 225/35r18's on the front and 18x10 225/40r18's on the rears with a pretty aggressive offset and i have no issues..
Those tyre sizes sound pretty small to me - a 225 on a 10" rim is an inch narrower than the rim.
Now I know that there is a 'look' for that kind of thing. But for regular use, I'd personally be running wider rubber all round.
A 245 on the front, and 265 on the back perhaps?
that rear tyres doesnt look any where stretched enough to be a 225 on a 10" either...
what offset is the 18x10 as well?
a mate of mine has a set of 18x10 +20 LM GT's, they only JUST clear the rear strut, and stick out of the guards. they also have 235's stretched over them. i'd say your rear rims are 18x9, 18x9.5 at most.
What is your gaurd lip to centre of hub measurements? What shocks & springs do you have?
Hi skidkid. is that measured with the wheel off ? sorry i am very new to this sort of thing ?
i am running hks hipermax perfomer coilovers and as you can see on the rear, the wheels must be just scrubbing it. don't know spring rates, only that it looks like there are two different rate springs on the one shock
pics
post-58831-1235165552_thumb.jpgpost-58831-1235165567_thumb.jpg[attachm
ent=207840:DSCF8823__1_.jpg]
So did I... if you mean this sort of thing:
Is that the new way of listing that you're talking about? I found that my post style had been switched to that way one day, and I hated it. But I discovered that you can switch back to the 'normal' style by using the "Options" button at the top-right-corner of the page, here:
Just select "Switch to: Standard" instead of "Outline" ("Outline" is the weird one in that first picture).
a little OT but HTH...
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
