We can't wait any longer to find an ecu for our S2 Stagea auto. The std ecu couldn't be fixed (BUGGER)! Have rang lots of wreckers with no luck and my local nissan can't even get back to me. We are going to have a Vi-pec ecu board fitted next week. It is going to clean out the piggy bank but I am looking foward to driving wagon again. I am going sell the Apexi SAFC and Jaycar boost controller that are wired in. I will sell Apexi Multi checker also if it can't be used. It will be interesting to see what wagon goes like. I have just o'hauled head after head gasket letting go on no. 6. At same time I match ported manifolds to head. While in machine shop they dedaged seat to port machining steps and smoothed chambers. I had injectors cleaned. I also fitted an adj. ex. gear at the same time as fitting a 100k km timing belt kit. Wagon allready had a k&n panel filter, full 3" exhaust and was running 10lbs boost. Head gasket blew 2 days before new years and wagon has been off road since. I am going to the blow cobwebs out once we get it tuned!!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/
Sounds exciting. I have been told that the Link (same as the Vipec) can handle autos (i.e. retarding timing etc during gear changes). I haven't taken it further because I can't afford one just now and I have found someone to make my ecu tunable but I believe you may need the top of the line model to handle the auto (but maybe not). I look forward to your results. If it goes well your car should fly with the stock turbo (more airflow for the same amount of boost) but you will also be set for a turbo upgrade in the future. keep us posted!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436361
I've been told the same thing from a Vipec dealer, which is good news because I was just told by the Haltech people that the e11v2 will NOT talk to the stock ecu. The only way to get the Haltech dropping timing on shifts is to attempt to intercept a signal from the gearbox when it changes gears and set that up as a flat-shift function in the Haltech :P
Keen to see how you go skidkid!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436617
surprised you didnt grab a chipped one from yahoo japan.
tested a S1 one recently, worked a treat, and the fella also had a S2 unit coming as well......
so they are around, used S1 or S2 ecu's chipped for Rom tune in Japan.
grab one, use safc to sort out the tune on your own car, and go from there? around $300 a unit.....
anyway best of luck
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4436717
I have been assured that the Vi-pec will run our S2 with an auto. If not I will not pay for it and I will have to hurt somebody!! Tangles; We decided not to go 2nd hand ecu because no warranty and Vi-pec can be tuned to our mods!!
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4437075
Ouch! :laugh:
$1760 for an ECU which is in my opinion one of the best available and is over $200 cheaper than a GTS-t Apexi Power FC which is quite a basic ecu compared to the Vi-PEC.
$750 for tuning
seems the going rate really...quality costs money
https://www.sau.com.au/forums/topic/257873-vi-pec-ecu/#findComment-4452631
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
