I recently returned from 3000 kms in my car. All the tanks were bp ultimate,
and I have the hks knock amp with display. No matter how I hammered
it, right up to 23psi, no knock..
on the way back home today @ goulburn couldn't see BP so went into a caltex and
got vortex. On the hume highway boosting in 5th gear, but only half max boost,
I got a knock reading. It was reproducible, so after that I limped the rest of
the way home being careful..
this is with a nismo ecu, not power-fc, ecu expects japanese 100 octane, and
retards with knock.
bp ultimate, it didn't knock even with intake temps at 45 degrees and 22 psi.
this wasn't a small servo. Could they be selling pulp as vortex 98?
https://www.sau.com.au/forums/topic/257942-vortex-vs-bp-ultimate/
The only time I've been forced to use Vortex 98 instead of V-Power or Ultimate was over Christmas south of Nowra (and my house got burgled whilst away). I was livid!!!!!!!!!
Bad Vortex at only ONE/1/UNO location? NOOOOO! Not on your sweet bippy!
Lower Blue Mtns Vortex 98 has offered bad fuel too!!!
OANA = Once And Never Again!!!!
It took me 3 weeks and 3 fills to get rid of the WRX burble-burble on cold temp.
Running with HKS F-Con Pro-V ECU and mild boost on BLITZ DSBC
On tha way back home from Nowra, I stay away from that Vortex sh/t. And C'tex has had a bad reput'n for bad fuel for some time eh?
I thought the missfiring was the coilpacks/ignition module for a while
Only trust 98 from BP or Shell
Edited by CARSICK
Aren't v-power and ultimate 98's anyways?
I prefer v-power, but seem to require petrol when caltex is up ahead.
to be hoenst i have not noticed anything different
ive tried them all....
even the 'V-power 2' offered in selected Shell servos...
which said it was 101 octane...
if I didn't get a tank of shite then it may depend on the tune,
if you were tuned for 98 and have a safety margin then, yeah, probably no diff.
But if you have less margin then it might. I don't know which is the case. I told my tuner
today and they said vortex: just say no.
I used Bp Ultimate exclusively, up until that fuel shortage.
that's when i used vortex for the first time. the car felt fine. pulled hard. no difference at all.
and because its slightly more convenient, and always cheaper, i just kept using it.
its been months, and i havent had an issue with it.
i guess it depends on the servo, in these cases.
but from all the reading ive done (which isnt really that much :thumbsup: ), ive found theres very little difference between the different brands of 98
well i heard otherwise........i heard a tuner say MOBILE SYNERGY is the best.......
anyhow ..i dont see it as a real big deal though....
has anyone here tried "V-power 2"???? or also may have been called "V-power Racing"
its rare as hen's teeths.......... ive only seen ONE ...SHELL station sell it in West Ryde..
although it was 100 or 101ron............i think it got phased out due to its High Cost........so they kept the standard V power...
I only run V-Power tried the V-power Racing and didn't find a difference, probably burns a bit cleaner i spose. Only time I have seen knock is when i had three other people in the car and knocked under load at full boost. :)
oh shit i forget to get petrol :)
yeah V Power Racing was phased out a while ago. The Vic club actually had a meeting with Shell to discuss it and try and keep it going. Turns out the money just wasn't there, even though the only people using it were the ones that would never get stingy about their fuel... kinda sux
I used to run vpower racing, LOVED IT! but it's gone now and it's tuned on 98... pings a little in third on a cold night on v power, so I think I'll try BP :)
Any idea why it would ping on a cold night, but not on a hot day? I'd imagine the opposite..
i have found the very same thing. BP and Mobil fuels were great, as soon as i chuck in vortex 98 the engine would knock its head off.
I just never use vortex anymore, it cannot handle running as hard as mobil and bp.
how does everyone notice/hear "engine knock" when driving ? How would you describe the sound ? I hear an occasional pop when downshifting but I'm pretty sure that's from the exhaust with excess fuel being burnt...
it'll rattle like a diesel and you can't miss the flashing check engine light. All 98s are the same this had been discussed and tested by many a sau punter and magazines galore. Apart from the odd bad batch of fuel they also all come from caltex which supplies it to your beloved bp, which slugs an extra 4c per litre more than others sell it for.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
