I was tossing up buying these or sparco pins when I first got my carbon bonnet on... I went the pins and slightly regret my decision :)
Oh well, that's laziness for you. Also, the guys at Revolution weren't 100% positive that I could line them up on the bonnet to sit perfectly flush but they hasn't been around that long at the time. Looks like they can be.
Looks good guys, but at what point doesnt the standard bonnet latch work?
Hi Mick, there's no problem with the factory catch at all mate.
I went with these for a couple of reasons.
1. I went to a GTR bonnet so rather than get the GTR catch panel or modify my original I got rid of the catch panel, catch, and cable alltogether. All that weighed about 3.7kg. Also aids in airflow to the radiator.
2. With the cage in my car it was very hard to pull the bonnet cable, so now the service crew can just lift it without me having to unbuckle and throw my neck out.
Ok, then where is the quickest and easiest pace to get them. Better shoot them off to the panel beater before the bonnet gets sprayed. Stuart?
They may look ok on my car since i am doing the fan boy black and silver thing :)
I did mine after the bonnet was sprayed Roy, no big deal either way.
Here's Stu's direct email; [email protected] , he could post them wherever mate. If you're talking to Russ again, maybe ask him if he has any spare sets, I remember he mentioned that a while back.
  • 2 months later...
Picked my car up today after getting the aerocatches fitted.
With the standard airbox it was a bastard of a job apparently. Thanks to Mick at Micolour it looks like a very neat job. It's the first time I've been there, he certainly knows his stuff. I'm sure I'll be back for some more car botox in the future.
post-21259-1243260939_thumb.jpg post-21259-1243261031_thumb.jpg post-21259-1243260999_thumb.jpg post-21259-1243261058_thumb.jpg
post-21259-1243261089_thumb.jpg post-21259-1243261117_thumb.jpg post-21259-1243261140_thumb.jpg
nice. What type/brand of bonnet is that Andrew? it's nice looking. :laugh:
It's a Varis "cooling bonnet" - I love engrish. www.varis.co.jp
Got it new through the Yahoo auctions at great expense (:banana: 60yen). The reason I chose it was because it has a neat little cover for the vent on the inside of the bonnet for when it rains.
Are bonnet pins necessary on a carbon fibre bonnet? I assume it's fine as is for road use, but i'm wondering about track day speeds if the wind can get under it and start flapping it around?
thanks mate.
and yes bonnet pins are very much a good idea on a carbon bonnet as they can and do flex when air gets underneath. even if they work with the factory latch at high speed air can get under and pull it out, or even break part of the bonnet so it's a much better idea to have it fixed at each side as well.
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
