As i said before the car drives really well for the power it makes.we all know you cant use 550kw on the street so as for anything over 350kw being usless your right.
But i built the car to race on a wed night street meet at the drags on radial street tyres.
No its not a race car if anyone wants to go for a cruise im more than happy to go :D
Paul i dont know why they didnt have it in shoot out mode ill ask and let you know
Thanx
Edited by superjet760
  • Replies 165
i just cannot see how that car could be usefull in getting good times on the drag strip. I would like someone to explain it to me if possible.. (serious request)
If that japs were getting good times with a smaller capacity then the 3L motor here then why won't it work is the question, the car still has a full boost band of 4,000 rpm which at this stage for a " street tune " is more than enough, coupled with the power and extra torque from the larger cc motor is should do very well?
How will it be at a drag strip?
Old school vid, same turbos, 2.6L though
Fast forward to 4.26
It will be a monster :D
Whats the time limit bfore WSID boot people out? 10.00?
but does it have such a narrow band of power?
i soo enjoyed that video :)
Thanx
Hell I am happy to go for a cruise !!!!!!. You drive, I ride shotgun in the passenger seat.!
But fantastic result and a Gorgeous car
Well with some well suited ratio's in the box and diff and getting the power to the ground without wheelspin is the way it will cut a good time at the track! Just because it makes huge power later in the rev range doesn't make it worse off, you just have to match the power & revs to the right gears and tyres..
rev limit 9000 rpm on standard crank? Be careful with that man...
RIPS has been known to spin his up to near 10,000rpm - his 240Z's RB30 has been running standard crank for as long as it has been running and it started off in the 10s and has been working through to low 8s with a LOT of runs under its belt, the stock cranks seem to do ok with proper care etc.
Check this out:
Check this out:
2nd that, they've been running consistant low to mid 8's with a stock crank, have been for a while now, their car and other customers cars over 1000hp are also running stock cranks and reving to high numbers, and they've never had an engine failure, ever, just goes to show the rb series cranks can handle some spin when prepped right!
