i just sourced an r34 rb26 soo i will be selling/parting out my 607rwhp rb25 to upgrade to a big borgwarner turbo and 9k rpms big 280 cams single stage external oil pump etc etc but i have my tomei rods on my engine i know i can use but can i use my cp pistons from my rb25 on the 26?
Just looking at the ACL site, it shows that the RB25 / RB26 pistons are different in 2 areas:
Crown volume - RB26 = 16.3cc, RB25 = 11.5cc
Comp Height - RB26 = 30.3mm, RB25 = 31.3mm
I think the Comp Height difference means you will smash a RB25 piston into the head of a RB26, because the piston sits higher on the gudgeon pin / small end.
I would imagine most others are the same.
And RB265 / RB26 have different stroke, so you probably can't use the same rods either.
well your totally wrong about the rods they fit either engine, the rb26 has 2 more mm's of stroke but it has 1 mm less of compreson height, and the dome cc's compensate for the extra mm of stroke thats my theory ive talked to soem engine builders in the states and they told me ill be fine i entered all the calculations on my engine calculator shows 8.1 compresion just want to knwo if thiers something im missing or if thiers something that wont fit
Why ask if you're going to research and find the answer yourself???
Big mistake.............Good luck! ;)
You cannot use the rb25 pistons in the 26, due to different deck height, comp height, gudgeon pin height.
I say we let him work it out himself as he's gotten some excellent advice................
Big mistake.............Good luck! :(
we'll see, and if you look at my first post i never asked if my rods would fit i know my rods fit they are rb26 rods no brainer thier suposedly with a stock height head gasket and the 25 pistons i should be at 7.8 compresion and if you dont want to help me im prety sure thier are other people who know more then you on this forum :) to bad all my aussie freinds dont know crap about rb26's heh talkinga bout you antony 2rismo rezlo cjmark
oi.. Raegan is a cool dude. He has been through some bad shit more then most of us put together. Nothing wrong with Peru, i would go there.
log on msnger fool i want to talk to you
lol he's TOTALLY wrong? heh ur arrogant..
Yup, a good bloke.........
He may have been through some shit man, but it doesn't excuse talking to people like shit trying to help him.
He's getting advice, he should be thankful and not take what he's being given for granted, even if his mates in the US know everything.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
