I've noticed that my R32 (early) gearbox is now leaking.
It's been a bit recalictrant through the gears for a while (still fine though), and 5th syncro is crap until the fluid is warmed up.
The options (cheapest to most expesive) are:
1. replace the seals only, run redline in it
2. replace seals, rebuild with new bearings and syncros
3. replace box entirely with new nissan late model series 3 GTR box (3500? + labour)
4. rebuild box with OS gearset (4700 just jap + 1400 new parts + labour)
Depending on the prognosis of how much (1) is, I am leaning towards option 3.
As the later boxes are pull type, and mine is push, is it simply a case of reversing the slave on the box and using the existing fork?
Oh and is is a bitch of a job to swap a box over?
any advice?
https://www.sau.com.au/forums/topic/258547-r32-gtr-gearbox/
Yeah we went option 3 in the race car and I'm very happy with it, its lasted years of (careful) race use. much smoother, its a real joy to use compared to the 150000klm old one was.
Not really must involved in converting it back to push, you just reuse the gearbox front plate and fork from the old box and tap holes for the slave cylinder (the mounting points are cast in). So the only labour cost is R&R gearbox and swap plate over (about 1hr I guess)
I'm not sure on your prices though, I bought mine a fair bit cheaper than that. Just Jap have them in stock, not sure of the current prices.
2 just doesn't stack up price wise, 4 is the way to go if you are worried about breaking it. But under 300kw it shouldnt be a problem unless you abuse it.
https://www.sau.com.au/forums/topic/258547-r32-gtr-gearbox/#findComment-4444405
thanks fellas, just priced it up and a new box is $2700ish. that's if they're in stock in JP...
I take it that this is how to do the conversion
RB Push/Pull Clutch Conversion
plus I take it this is really not necessary:
Clutch Pull to push conversion-
Late Model R32, R33
Front cover assembly :32110-05U11 (japan part only)
Gasket :32112-05U12
Clutch fork :30531-01S00 (same part for a 1991-1993 240SX)
Spring :30514-14600
Spring :30534-E9000
T/O bearing :30502-14601
Bearing sleeve:30501-S0160 / 30501-N1601 (14mm for twin / trip disc)
Bearing sleeve: 30501-K0404 (24mm for single disc)
Dust cover :30542-31610
Slave cylinder :30620-21U01
Flywheel bolt: 12315-04U00
https://www.sau.com.au/forums/topic/258547-r32-gtr-gearbox/#findComment-4444421
just had a better look under the car - looks to be the transfer case leaking.
is it best to just do the seals on that guy?
If I were you man I'd drop the box and do a rebuild. If you're having problems with the syncros or gears you may as kill two birds with one stone.
If you have the ability - do it yourself, otherwise it'll cost you a pretty penny.
Going with a secondhand gearbox you don't know what you're getting.
https://www.sau.com.au/forums/topic/258547-r32-gtr-gearbox/#findComment-4446629
Im also thinking of relpacing my Gearbox and diff actually :S
I sell bearings so i can get the gearbox bearings pretty damn cheap and i can get syncros at a decent price as well.
but....
i cant do it myself and also i heard that the R33 Gbox has stronger syncros? but the pull push conversion can be pricey?
also a R33 diff fit a R32? 2nd hand or aftermarket?
cheers
https://www.sau.com.au/forums/topic/258547-r32-gtr-gearbox/#findComment-4447558
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
