This is an angry rant on my behalf.
Now i live on the diamond creek side of eltham.. only a hop skip and a jump away from kinglake and St. Andrews, the fires have affected us all in some way or another, whether it be ourselves or someone we know some how..
living fairly close to the devistation i know quite a few people who have been badly affected by all this! fortunatly not myself dirrectly.
Anyhow driving out to a mates place in hurstbridge tongiht, i'm following this wrx... next thing *BAM* flash of orange light ... the douche bag has thrown this lit ciggarette butt out the window, i was so enraged at this point and trying to memorise his rego whilst following him so i can give him a blasting!
especially with the fires still fresh in our mind, and mind you still allight allover the state can people be so careless and do such a thing.. it just makes me so angry!
last time i checked 2002 wrx's have perfectly good ash trays!
unfortunatly i was so angry and not having a pen and paper, i forgot the rego!
he quickly swerved off and drove down a side road in hurstbridge (5 or so minutes drive from St.Andrews where about 23 people died in the fires) so assuming he lives there he should be well aware of the area and the fire hazards and dangers!
so to the 40+ year old driver... YOU SHOULD KNOW BETTER YOU #$%^#$% IDIOT, not only are you littering, you could have potentially started another fire!
GGRRRRRRRRRRRRRR
/end rant
https://www.sau.com.au/forums/topic/258693-idiots-and-thier-butts/
  • Replies 47
That's amazing!
Why on earth would someone do such a thing?
Perhaps he flicked it out on habit, completely forgot what area he was in.
In any case, you should never flick cigarette butts out the window.
Would have been good to get his rego.
That's why I carry a note pad & pen in the car.
Couldn't count how many rego's & car description I have written down and submitted to EPA.
No stereo types either, luxury car drivers, elderly drivers, P platers, Soccer Mums... I don't care who they are!
DO NOT DUMP YOUR CIGARETTE WASTE OUT OF YOUR CAR :D
Which reminds me, I have to report a P plater who threw his lit but out the passenger window and into the langwarrin flora and fauna reserve off Warrandyte Rd last night.
Unbelievable!!
Edited by iamhe77
Couldn't agree more guys, have you all noticed how many small fires there have been along our freeways latley? One guess why! Friend of mine saw a guy throw a butt out his windows at Knox and start a fire in the garden. Pick them up and throw them back in the car I say :D
Agree with Nate, however I smoke once in a blue moon in my car, usually after a tough day.
I am surprised there isn't a bit of an awareness campaign focusing on bush fires and cigarette butts in addition to the normal "don't litter" msg.
I always try to make sure I have a drink with me so i can put my cigarettes out in that once ive finished - I ash out the window tho and have lost it with the wind a few times and even had my seat cover burnt :D *damn you cigarettes!*
shit when i walk to work and i throw my butt out and i miss stepping on it i purposely turn around and make sure that its out. Must be all the fire talk.
How about you try using a bin, maybe you wont have that problem then huh!? You smokers dropping butts all ove the ground really give me the shits - you're just as bad as the people throwing them out the window.
thats why you use the mirror as a windshield when you ash lol
Maybe it's time you finally quit fool :D Stop putting it off!
ahh im going to have to try this on the way to work soon lol
I also find that ash flys back and hits the plastic/rubber on the door frame and it gets all these white dots and I need to rub them off and then even worse is when ash blows into the back and on the seats - its like vacuuming sand off my back seats.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
