To the SAU group of members,
I would just like to say it has been a fantastic 3-4 years contributing to this excellent site. I have met and made friends with many on the site in and around Brisbane. SAU has got to be the most respectable and largest forum that I know, where there is a large wealth of information ready at your finger tips.
It is time for me to depart from the forums for a little while, maybe a couple of years. I recently sold the R32, the second one I owned, and now have moved on into the rotary world.
May you all enjoy your rides and keep developing this site more on top of what it already is.
Peace and farewell,
00MFG (Arbess)
Edited by arbess
https://www.sau.com.au/forums/topic/258725-bye-bye-for-now-at-least/
Which chook cooker did you go for mate.........I like the Series 4 RX7's (shape) although the interiors look real oldschool
You know you will be back...........It will go well for a while and then blow up. Then you will miss the reliability of your old 32 :D
Good luck mate :D , we will be here when you come back.........
LOL @ your replies.... your supposed to wish me well.
But yes there will be a time where I will consider the RB's again. Though when people say reliability of the RB's, I would agree but only to the extent of the engine itself, the remaining car itself can be questionable.
Yes I am in an RX-8 and wait for it................................................ warrranty........................................... cheap insurance.................................... and lots of head turns for the possies out there.
I will try and head out to events as the rx8 club seems a little "inactive" and the boostcrusing club are a bunch of "[insert imaginative word here]".
Look out for me if and when I come back because it will NOT be in a 32 or 33, nor will I be in single turbo set up, as per usual.
My departing quote is "With great power comes great brakes" - Superman with boost.
RX8 mmmmmmm is it pink or yellow and have you put the frangapani on the back lol............. :)
Very nice car but yes I agree underpowered.......Pity they didn't boost it like the last one.....a factory turbo version would have sold well
Apparently they do handle very well judging by the reviews I have read about them over the years.......
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
