How come noone seems to rate the Greddy EMU as an alternative to the PFC? I know it is still a Piggy Back Computer but I have had one for around 12 months and am really happy with it (Bought it back when PFC's were very scarce and VERY expensive!)and last time I checked which was a while ago they were a little cheaper than a PFC
Is there something I dont know about the EMU??
Had it installed by Jim at CRD and he seems to rate them just as high as a PFC
Sorry for the thread jump
it depends on your aims.... i have a power fc in my street car (300rwkw) and couldn't do without it...
i'm building up a ke70 drift pig with an SR20 and will probably just go with a safc for $$$ sake... the car is getting stripped and should weigh 900kgs give or take so i dont need massive power... 180rwkw (using my old 33 turbo) or so is the same power to weight as around 270rwkw in a full weight 33gtst.
the ke70 will be a rough car though... and if i get real shitty with the lack of timing i might buy a 2nd hand SITC in the future...
just to show an example of how its not always needed...
The money you spend on a SAFC you could get a toshi/doctor drift remap of your std ecu and do so much more with it, its not a pfc, but its way better than a SAFC.
So bang for bucks as a first step is rechip imo.
read this and other threads like it:
http://www.skylinesaustralia.com/forums/Ec...l&hl=doctor
This is what i wanted to do. But i would much prefer a Toshi remap with the road tune he does. I was a bit wary of just telling him my mods list and getting a re-map. He was asking for the temps i get over in NZ etc. He even said it would need to be dyno'd and touched up as required anyway. So theres more cost for that option :stupid:
If he flew over however.. :)
I would lean towards a full ecu if possible.
Im in a similar boat. My turbo is on its way out and have eyed up a larger turbo which ill be getting very soon. I bought a BRAND new SAFC Neo for peanuts(mates rates). However im contemplating whether to have it tuned or sell it, put the money aside, save up for a Link G4 and get it tuned once and for all.
Like everyone said tho, if you have a stock turbo you could do with a safc, however, when you do get 200rwkw, i bet you my bottom dollar that you WILL want more, and then you will realise "Doh, iv hit a brick wall". I know its hard, but you will end up saving money in the long run.
Just my 2c.
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
