Yeah consistance wins DECA. This will always be the case. If your fast, but hit hats then you almost can't win against a slower, but consistant compedator.
If we would have had another say two events I might have been able to claw back the other 6 points to catch ryan. But with a single day event you need to drive clean to win.
Not that i'm complaining, i'm happy to see ryan win DECA. It would be boring if the one person always won.
  • Replies 155
Posted Images
I'd Also like to acknowledge Che Boocock, Tom Giordano and Russell Cunningham. You all drove well to beat some faster cars and a fair few 4WD cars.
Also Tim did very well considering Mick broke his car and he had a one DNS. To still get 9th outright is great.
cheers for the results guys,
Happy with 9th overall condiering mick broke my car, and last run i drove an understeer king for the 1st time ( r32gtr)
that was an experiance.....
Grats to ryan , RWD represent. Really happy for you mate
cheers
Congrats Ryan!!!!
It's good to see the 4wd's kicked off the pedestal.
Top effort Che!!
I'm proof that power does not achieve better results. In fact the more power i have the worse i get; In the first year of DECA i came 4th overall, since then it has been spin-outs and burnouts :bunny:
Good work ryan!
Al, I think the first DECA I did was probably the best one because I just drove properly..instead of trying to get the arse end out whenever I can! Although It might be time to try and find a good balance between the two and get some good times down. Next time.
Good work ryan!
And fun :)
Exactly!
I treat DECA as a fun/drift/thrash day.
It was my intention to do this DECA properly, i even left my new, $660, 400km old, tyres on the rear; but as soon as i went "WD" on the first run (because someone made me go first), i said fark it. Then just wanted to do what i do best!
Thanks guys.
Its cool to see out of the top 5, 4 were RWD. Two of them being Dean and Jamie's Porkas... those things were damn fast. Congrats to Jamie on the fasted back track time. would like to see what they could get around HH.
Standouts to Che and Tom for sure! Russ, considering you spun like 10 times im keen to see what you would have got if you kept it clean!
dang! 5th is a surprise :)
thanks for organising the results guys and well done to everyone that competed
Don't you mean 4th. Well done.
Dean Taylor Porsche 484
Che Boocock R33GTST 484
Thanks to the organisers and volunteers for running a great event. Its great to see so many rwds near the top of the results sheet, and I'm really surprised by my result.
Hopefully Dean and Jamie can bring the Porsches again in the future, it was good to see something a bit different out there, and they were very quick.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
