Hi all,
i was wondering if these fog lights fitted to the stag are a factory option or not ?
There is a switch to the lower left of the steering wheel that flicks between the original foggies or the bottom mounted ones .
also could someone do a fast check for me if possible just to see what comes up ?
6U900WGNC34129431
many thanks
Edited by Jezboosted
https://www.sau.com.au/forums/topic/259169-fast-check-please/
Yeah I had the exact same spotlights fitted and the same switch. Only my switch was located to the right of the steering wheel in one of the switch blank spots. I have since removed my spots as I cut out my front bumper for my intercoller but the switch is still there.
i dont think so, i think they are an option with the DAYZ kit etc....
tear it down. you will find it will be scotchlocked in place. most of them I have seen are dealer fitted.
they are definatly a DAYZ option. maybe factry fit on some and dealer on others...?
i'm got some that i fitted and they wont go, is there any chance i can buy the switch and any wires related to it? i've got all the engine bay wires and the factory loom has the plug for them infront of the battery but i think there's some bits missing under the dash. i didnt get the dash switch and the car i got the lights from didnt have it, the lights were controlled by the stalk which just had another position on the little fog light twisty thing. should all be seperate from the dash loom etc. i can supply a blank dash plug thing too. might even get away with a picture of where the wires join the factory loom...
D.
Hi all,
6U900WGNC34129431
many thanks
Just to throw another spanner in the works . The switch for my dayz kitted s2 is on the indicater stalk . Similar to the wiper delay on other side .
yeh that was the same as the car i got mine from. i think maybe some were factory fitted and some were dealer fitted... coz that switch seems to be in different spots for each car that its in and just not in some at all
D.
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
