  • Replies 66
^ very nice photos.. r32bigboy and brokas..
r32bigboy - guessing you got a 100-400mm lens??
anyways.. hmmm
Ok i dont know what i have done today.. My brain did something i would normally never ever do!!
I just purchased a Canon EF 70-200mm F4L USM!!!
My first L lens. Hopefully i should get it by Tuesday so i can test it out at a track event on wednesday.
SO notice anything here?? haha
I got heaps more..
If you keen its on my blog site (www.sidd-rishi.com/blog)
Havnt uploaded them all yet.. but will try and do so by tomorrow
Edited by siddr20
damn photobucket with bandwidth exceeded messages :D
I made a new account anyways..
Here are the pics sorry
wont post them all up coz in few weeks my other account should work.
sidd-rishi.com/blog for more images :)
Lovely picture
hahahh thanks man :)
So did you guess it yet? :D
Edited by siddr20
So did you guess it yet? :)
I'm not sure but i'd guess you reckon those unique taillights :D
Naah whatever i'll dissolve it right now.
*drum roll*.......There is a chance that you mean those glowing brake discs :)
But *pssht* I didn't say that :P
Best wishes from Europe
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
