I need ur recommendations on a workshop to tune my safc.
I've called a few places and the prices vary heaps, some are ridiculous!
This is what I've asked for when calling:
I have a R33 GTS-T, 3" turbo back exhaust, 12psi, and a different filter. I would like a price for tuning an already installed Apexi SAFC on the dyno please. (there's my scripting for the day :) )
So far my quotes are:
Hills Motorsport $600 ---- WTF????
Croydon $400-450--- another WTF????
BD4s $135-145 (not too bad..)
Obviously Hills and Croydon have no idea what they're talking about.
Can anyone recommend somewhere else in sydney? I'm from Parra area but can travel to Penrith or East no problems.
Thanks in advance.
Same as melbourne.. there is places that will charge you $400 (not mentioning names) to do what another would charge you $100 for. Pays to shop around, but I'd say that last one seems best if you ask me.
I've had a really expensive tune, and a cheaper one - noticed no difference in the end results.
Spare a thought for us canberrens, Nobody here can touch any HKS / Apexi / Jap stuff confidently.. Only Microtech / Digitech..
Go with Silverwater or BD4's - I hear good things about them.. Bd4's quoted me 250 - 1000, (and possibly a week) to fully tune My HKS F-CON V Pro... (Still havent got around to it)
But the different quotes *must* be for different amounts of work, right?
Well I hope not! I have asked all of the companies the same questions. I didn't add or take from the job mentioned above, that way I can compare quotes for the same amount of work. I suppose some of them are either dumb ie. don't know what an safc is and are too afraid to ask so they over quote to get rid of me, or they're just plain rip-offs!
Thanks T0nyGTSt, I called Unigroup first as they're only 5mins from my house, but no one was there so I left a msg. Meanwhile ProCar at DeeWhy (yes, it's a fair hike) called me back and gave me a reasonable quote of $125 or under. The guy on the phone was nice and seemed to know what he was talking about compared to the other companies mentioned above (except for BD4s) so i booked in for saturday after next :rofl:
Hi firebladejr, in Sydney dyno time is around $120 per hour. So, using your $145 quote, if you allow for loading, tie down, sensor fitting, dyno parameter set up, unloading etc there is only around 40 to 45 minutes available to tune the SAFC. Now if you know what you are doing you can tune the SAFC pretty well in that time. But I wouldn't expect anything else, no time to do stuff like check the fuel pressure, adjust the ignition timing, check the boost stability, check to make sure there is no problems with the A/F ratios in excessively hot or cold conditions, hot start, cruise fule economy, idle stability with a/c on etc etc.
Pay $145 to tune the SAFC and that is exactly what you will get, not one thing more. But, personally, I would want to optimise the performance available from the correct A/F ratios achieved by fitting the SAFC. I would want them to check if I could sneak a bit more boost, if I could advance the ignition timing, if there was a fuel pressure problem (pump failing), if the boost controller was holding stable under all conditions etc etc. I would also want to make sure there was not going to be any problems under a wide range of conditions.
So maybe the low quote was ONLY for tuning the SAFC, nothing else and the higher quotes were allowing for a (what I would consider reasonable) level of care and improved performance above that.
I'd like a dollar for every time someone has told me to ONLY do "X", and then come back when "Y" fails and ask me why I didn't check that as well.
Maybe you should ask them a few more questions.
Firebladejr,
I'm very interested to read your comments on how you go with getting your S-AFC tuned. I'll be getting an S-AFC II in about a month. I'll be looking for someone to fit and tune the thing for me.
I've dealt with Rick Shaw in the past. The service was good and the prices were very reasonable. I'm just not sure how much they know about Apexi products or tuning them correctly.
I have also dealt with BD4's as well. The service was so-so but they were abit pricier than Rick Shaw. Again...how well do they know Apexi products? I know they use alot of HKS products though.
I've always heard good things about BD4's and $145 sounds like a good price, seeing as they have tuned some serious cars previously.
Wouldn't recommend hills motorsports though,ESPECIALLY AT $600! pm for further details if interested.
I paid $150 for my S-AFC tune at Hills a couple of months back. It took around 2 hours (he did have to leave the job for a few minutes every now and then to tend to other stuff though) and it involved adjusting the timing. Are you sure they didn't think you were referring to a PowerFC tune? I understand that they can cost upwards of $500. Also, the last time I got a quote from CRD they quoted me $200 or so. But that was almost a year ago.
Firebladejr,
I got my powerFC tuned at Procar in Dee Why. They set up my fuel system (I had a fuel pump and regulator installed a few days prior to the tune).
The guy who tuned it took about 4 hours on the dyno whilst I sat in the passenger seat watching the engine check light for him while he did his maths and explained what he was doing.
After he was happy with the tune he reduced the timing by 2 and set a safety net somehow so if the powerfc notices very very unlikely readings it will handle things so the engine doesn't blow.
I requested that the tune had to be on the safe side becuase I havent got the $$ to buy another engine in 6 months time. He told me he does this to every job.
bbenny is another to ask on the forums about procar. He has a HKS powered R32 and has used procar for a dyno run. I think he was getting a safc tuned there are well.
Mark
Originally posted by MRK25T
Firebladejr,
I would like to know what this is since I was under the impression the PFC doesn't have any Detenation controlled timing retard....
Firebladejr,
Thats what he told me, i've got no idea if its true or false - it sounded safe to me so I was happy.
Mark
i got my safc tuned on the road by my mech.. $10
to me i feel being tuned on the road is a little more realistic as there are things like cold air etc etc....
also they way u drive it
im happy with my $10 spent
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
