Up for sale is just some random bits that I have collected unneccesarily over the years!
All prices are negotiable, pick up from Sydney west, I will post at buyers expense.
R33 SERIES 2 bonnet S badge
Great condition
$20
R33 GT badges pair
Good condition
$50
R33 SERIES 2 Dash facia surround, comes with clock and all switches and vents
Great condition
$100
R33 SERIES 2 Centre console with cup holder type centre and perfect handbrake boot
Good condition
$30
R33 Stock parcel shelf with no holes cut
Good condition
$20
R33 Rearview mirror
Great condition
$20
R33 Stock Rotors SET OF 4 removed due to going slotted
Good condition just need a light machine due to surface rust, plenty of meat left!
$40
R33 Assorted boot trim pieces, imcomplete set have some doubbles also
Average conditon depending on what piece you choose
$5 a piece or free if you buy something from above!!
I have some other interior bits too so just PM me and I might be able to help
Edited by ThirtyThree
https://www.sau.com.au/forums/topic/259542-fs-r33-parts-clearout/
Good condition
$30
Do you also get the ash tray for the back passengers as well? How much for shipping on the GT Badges and Console to SA, if you are willing to post.
I Bags the S Badge
PM replied
damn... 15 mins to late for the S badge..!
You know you want some GT bades :bunny:
Good condition
$30
PM sent
have you got the steering column surround? Is it completely unmarked, if so, ill take it. I would also take the lid bit to the centre console
no steering column surround that i know of but ill check for ya. PM sent
$40
can i get a measured thickness on these?
Im assuming there gtst and not gts?
Edited by W0rp3D
where abouts in Sydney are you?
hills area
gtst and ill get back to you on thickness
Hey mate...just wanna know how much for the centre console and rearview mirror posted to Brisbane 4152
PM sent
do the s2 dash surround fit on the s1? they look about the same... if so i'm interested
Hey mate the series 2 and series one are interchangeable, the series 2 one is a little more modern looking as it has a slightly different shape, to yours if you look closely at it, and the series 2 oen doesn't have that little coin holder thing next to the mirror switches which looks like it was useless anyway!
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
    • The old approach was to fill the cylinder/chamber with a length of rope pushed in through the sparkplug hole. The new approach is to connect compressed air to the sparkplug hole and fill it with enough pressure to push the valves up. Doing either of these things with the head on and the engine in the car is a lot less pleasant than doing it properly.
    • Can't you put the pistons to TDC and then do the valve seals? Or will the drop down too far to pull them back up?
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
