I have seen a skyline (first time i have seen this one) in my street tonight.
It has no number plates front or rear.
I am wondering if it has been pinched and then dumped (the Hornsby area is not a common place for dumping cars but....)
so i am thinking should i report it to the police or not.
I would hate to report it if it wasn't stolen and cause trouble for the owner but
I would hate it more if someone did dump it but then came back to tow it away later or whatever.
Any way its a white 33 with mags on the rears and stockish rims on the front.
If you hear of someone losing one pm me with a description and if satisfied I will tell you which street it is on
https://www.sau.com.au/forums/topic/259808-stolen/
Report to the police, they will find a way to identify the car, but more than likely door knock the houses around the area to check for an owner.
If it's stolen, someone might get thier pride back, if it's not stolen, then you at least gave the police a bit of excersise for the night, no harm done.
B.
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4460627
I would check with the house that it's directly out the front of first, and if it's not theirs, then report it to the cops before it starts missing parts :P
It could be the difference to someone getting their pride and joy back in one piece :laugh:
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4460651
I would check with the house that it's directly out the front of first, and if it's not theirs, then report it to the cops before it starts missing parts :D
It could be the difference to someone getting their pride and joy back in one piece :(
Makes sense.
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4461891
B.
They will indentify the car by reading the rego label details....very very easy....unless rego label is not there due to smashed window...If window smashed, car can be unlocked, bonnet popped and vin plate read...If vin plate is not there engine number can be read..if engine is not there, check that car is still there...If no car or engine exists it may not be stolen because for a car to be stolen it first must exist....ddeeeeppppp
https://www.sau.com.au/forums/topic/259808-stolen/#findComment-4461919
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
