sounds like a plan
i might even come down friday night too and catch up with everyone :P
You can crash at our place if needs? We live just up the road from City Dismantlers. :D
  • Replies 499
Posted Images
Righteo! So if no one has a problem with it, we'll all meet at City Dismantlers for a 1.30pm departure (meet from 1.00pm). :D
Craig, can I put myself down for a secure parking spot also? :D
Rest assured we ALL want secure parking facilities ... methinks it will be first in, best dressed when we get there :P
wait, wait, wait
now before we all get into an argument on who gets the parking space and all
i do believe that shotgun has not yet been called.
so hence
SHOTGUN ON SAFE PARKING SPACE FOR MISS BETSY
:D
put me down for a parking spot locked up please, priess
cheers
SHOTGUN on the secure parking as well
Righteo! So if no one has a problem with it, we'll all meet at City Dismantlers for a 1.30pm departure (meet from 1.00pm). :yes:
Craig, can I put myself down for a secure parking spot also? ;)
i will meet catch up with you guys as you go past the Caltex off port wakefield road....as going to city dismantlers is the opposite direction for me so why track back
i will just cruise along and meet u peeps on z road
if thats ok ruby i might take you up on that offer would be great if i could thanks heaps ;):yes:
Alright! I'll sleep on the lounge ... don't you and Tracy mind the video camera at all okay? :D
Jokes.
No worries. I'll double check with Tracy, but that should be fine. What time you reckon you'd be coming up?
lol at all the shotgunning for secure parking.
If I do bring the bike up and there's no room left, I'll tow all your cars outta there with the truck!! :D:/
You won't need the truck, the tractor should be able to do it also :)
i am sure they will let you keep the bike in the room Pete :)
oi krish ya bum.. i should be at this. duno when ill be going up tho, got cristys bday the nite before, so either leave that early and drive up, or very early the next morning.. haha having family to stay with up there is awesome seeing no hotel fees :/
just filled my form out !
now time to run around like a headless chook and put my car back together !
well done mitch now i am not the only 33 in the display
will be a good one i reackon
ohh and stevo u should come up just for the laughs we going to have on sat night mate
yeah thinking about it. what u guys getting up to on the sat nite, wouldnt mind checking out the local nite life. haha and by nite life i meant 'the' pub open till 10pm haha. see what country slappers we can find krish lol. btw wont be in sau display obviously, as im taking my vr4 up there. i wasnt in the sau display last kadina show either, everyone just parked aronnd me lol.
if there is anyone at all that is wanting to enter at the last minute i will be in adelaide tomoro night at around 10.30. please sms me on 0430 18 34 34 to let me know if your gonna enter.......i will have entry forms with me!!!!!!!
giving your numbers out to everyone now cara aye :)
ohh steve i think we will be responsibly consuming alcohol bahahaha but it will be good as i havnt gone out with anyone here on a drinking session shall be good to see what sort of mix we have here and no country slappers for me mate hehe you can take them all for the team yo lol
Edited by Krishy
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
