firstly this is a mental exercise to figure out cost as I'm considering buying a sedan.
I did a bit of digging on these and like the TI/or silouette versions.
found costing on them in the $2k-5k area and I'm looking at RB25det halfcuts in manual form (ala R33 s2) -$2-3K
now the questions:
4 spot brakes - how? does R32,33/Z32,31 stuff swap to get 5 stud on the front,twin spot rears - how? - redrill or new axles?
lights - best version for HID lights ?
rear swaps (foudn some info on the R31 site) after the stovetop look now logic tells me that teh sheetmetal is the same - correct?
LSD (part of the reason I like the two models) what type? can you shove somethng else in it?
factory coolers - oil,Psteer,Geabox? - available? where (nissan?)
rust on body - where do I look?
theres probably more questions - I'll add to it as I go.
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/
mate... the place to go is
r31skylineclub
it is full of HEAPS of infoz on the R31.... just clic search and away you go
also check link to r31 project for sale
not too much in the way of R31 info here on SAU, as we kinda just choof em off to thr R31 forum...
good luck and bye bye...
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4482683
r31skylineclub
Thats cause we no care about R31's here :):sweat::)
But seriously r31 club is the best place to go for these cars!
BTW whats happened to FJ20.com?
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4487546
  • 3 weeks later...
now the questions:
Better off putting Z31 or GTS struts into a local car to get a floating hub setup. Local R31 has fixed hubs, whereas Z31 and GTS have floating hubs. Get your rears redrilled.
lights - best version for HID lights ? Any version will be fine. Lot's of people use the late model import lights, as these look like Xenons with HID globes in them
Sheetmetal is the same for all rear light fittings, even coupes. Stove top will bolt straight up. Make sure you get plenty of sealer in behind them so they don;t leak. You may have to fiddle with wiring looms, as they are different between the series.
Only the silhouette had the LSD, not the Ti. You can go to Kaaz LSD if you are wanting a tougher LSD.
Trans coolers are better from the aftermarket shelf, engine oil coolers, the local GTS had an excellent setup, but you will find these difficult to source from anywhere. Your only option may be aftermarket again.
Behind the front guards, local cars are shocking for rust where the firewall joins the inner guards, especially eastern seaboard cars. You can see rally bad stuff if it is there by looking at the drivers side A" pillar door hinges. If there is any sign of rust around the door hinge, it's a safe bet it has expensive rust to repair under the guards.
Lift up the rear boot seal and inspect, most will have minor rust there, but minor is easy to fix, major isn't. Some earlier cars experienced rust in the roof rails and where the "C" pillar meet the roof line. Other than that, you shouldn't find any bad rust on a local car.
I hope that helps with your questions.
R31 skyline club has an excellent tech section. Classic Skylines Australia is fairly new, but caters for the earleir model cars too.
I can help you with genuien parts if you were after any as well. Carsales is a fairly good place to look for good cars, adn tehre is always plenty of them available for sale on R31 Skyline Club. Plenty of people in there who know lots about these cars.
Edited by cazz
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4521992
thanks!!
I tried to buy TUFF31 on R31 and the owner didnt wish to reply to my postings. I was prepared to fly to SA and drive it back.
been looking at wrecks to gauge rust in the chassis onthem ( I spend a bit of time scouring local yards) and I now have a decent idea where to look.
didnt know about the Z31 connection. though if nissan is anything like subaru then anything fits anything.
with the rear end I figured redrill was the only way to do it. HR31 as I understand is a different kettle of fish. (been looking at HR31 coupes)
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4523055
Chris, a friend of mine has a s3 TI, white, stock as, paint needs a good cut, but is complete and all options still work, probably the cleanest engine bay I've seen in one, no rust in the usual spots, going cheap. Come from a 31 myself, there's a lot of common parts for upgrade. You're welcome to pm if interested.
Cheers, Dale
Edited by Daleo
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4525761
now the questions:
hi chris,
i've got a passage gt with a rb25 and 25 box... goes in relatively easy.
brake - 33 gts-t rotors/calipers fit all round on import struts (so coupe is fine) mine has 33 gts-t calipers, and rotors re-drilled to 4 stud.
the front hubs can be drilled to 5 stud, but the rears use a 'square' plate so it cant be drilled to suit, you can use Z31 rear hubs i believe, or possibly even get billet ones, depending on how much power you plan on throwing at it.
rear swaps - i assume you just mean tail lights? 99% sure they are a straight swap.
lsd - my factory lsd seems pretty decent, doesnt single peg. i do have a tomei 2 way sitting in the shed for it as well though.
my 31 has quite a few mods done, so if you have any questions can shoot me a pm. :(
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534718
s13 coilovers fit in the front if you use s13 hubs and some other bits (google this)
rear ones go in but need new holes drilling for the tops of them
they must be height adjustable ones tho otherwise it will be sitting on the ground
the lsd rebuild kit for a BA ford falcon is the same as an r31 borg warner lsd diff giving you a tight lsd for ~$200
they are good cars and go alright
could look at getting a cam too or even just getting a spare head from the wreckers and giving DIY port polishing a go
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534756
Sorry, it didn't load like I expected it to.
If you search Carsales.com.au your going to find a red GTSII which is for my money, a far better idea than bastardising another Ti/Silhouette & for similar end money.
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4534885
In October 06 I did a 1UZ conversion to an MX83 Cressida. I owned the car & wasn't buying it to convert.
The front cut cost me $2500 + frt from Adelaide, but by the time I had it wired, changed the suspension and brakes to comply for engineering, paid the engineer, the whole thing owes me more than 10K, so don't kid yourself, any conversion is the cheap way out.
If this conversion goes ahead, he won't get much change from 15K if it's done right. A good Silhouette is going to cost more than 2 or 3K and an R33 GTS25t manual front cut will cost more like 5K rather than 2 or 3.
Let's see, we have the car & front cut and spent 10K, we haven't fitted anything, not wired anything, we got SFA except some parts and a good Silhouette and your saying a good limited edition GTSII isn't value?
You have to be dreaming!
Cheers, D
https://www.sau.com.au/forums/topic/261107-r31-tisilouette/#findComment-4535193
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
