They would have to rape the character of the track to make it viable for a race :(
This is true.
Having said that, there has been many changes from the original layout which people will argue have wrecked the place, most of them in hte name of safety..
F1 car smashes Bathurst record
This is another thing too. It seems that everyone is suprised that the F1 broke the record. Seriously, what were people thinking? An F1 is a no-compromise race car. The Super Tourers are modifed road cars.
Here's some more vids.
Daniel-san, gonna be at BNR on Thurs? Got the coilpacks and ignitor off teh ute that McFly leant me.
McFly, turns out my mates cousin bought some new coilpacks and ignitor.
haven't been on it since last thursday actually, so going good, need to get time and bring it around to mine so i can do some servicing on it
No ice creamery goodness and titty staring for me this week :( Work and all that jazz. Hoping there isn't a delay on my radiator and trans cooler. Should have them deliverd to Dan at ERD on Monday if all goes well :)
Morning chaps!
Hopefully getting my roady done this week... all going well she could be gone on the weekend :) + :(
What's new around here? Oh I saw some massive lols in the general maintenence section yesterday, have a read of this
http://www.skylinesaustralia.com/forums/topic/357935-r33-gts-t-knocking-noise/
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
