what suburb are you guys in?
Who's that directed at?
Martin what phone did you get? I read a review on the first of the 4g androids the other day, apart from battery life draining in a few hours on 4g it looked pretty good
red maserati?? hardtop or soft top?
we had a 4200 GranSports yesterday and i think there was a GranSports Cabrio there too.
It was a soft top. Parked up at the rail with its bum to the street.
that would have been the cabrio, i did some work on that thing, not too bad at all, sounds nice. Engine from them will fit a skyline engine bay
Haha awesome!!!
Speaking of engines that fit into things, I need to run an idea past you at some point. Unless it's an LS engine, no one at work knows or cares.
you :P
I can see if one of our offices would take someone on for work experience
you :P
Haha, she's in Albany creek, she's public transport literate. I work in the city and travel caboolture train line so transport generally won't be a problem, unless it's in the middle of nowhere.
Morning Mangs
No ikes cream tonight. Going to support the dirty old man. Although I won't be able to vote as I'm not a member and I have no money to become a member until pay day :thumbsup:
bishes
out for agm and probably ice cream as well. shit to do, people to kill
Get pics. :thumbsup:
p.s. if theres any looting, pillaging, or raping involved gimme a call. :cheers:
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
