Hmmmm thats weird because we were asked last week to organise a cruise by the owner of nando's for this Anzac day .... with approval from centre management (the owner of nandos drives a RX7 series 8) :
lol good luck on the cruise :) we did a small cruise anzac day last yr. didnt see a single cop the whole drive but forgot to plan ahead...and got stuck at 3 lots of anzac parades.
most of which we found our way around. 1 we had to wait out (not too bad). but having said that we only had 7 cars
*carseldine was fine on thursday night...other than it being the start of the uber long weekend and very little parking to be found anywhere. (didnt head underneath). and it took me almost 10 mins to get off the road and into a park
Edited by boiracer
^^^ yeah cheers, fingers crossed should be a good night....!
SAU guys are also welcome obviously! (i'll be taking my skyline to the cruise)....
Its usually the bonnet release lever that snaps off the fuse box. Is the fuse box where the bonnet release mounts to it damaged at all? Its a common problem with BA/BF falcons for them to snap. I have changed a few of the bonnet releases over. You need to change the whole cable over with it. Absolute prick of a job to do.
Yep the latch has snapped off the fuse box, looks like the mounts are destroyed as well. A friend of mine took his to ford and got it replaced under warranty, they pulled the entire fuse box out and swapped it with one that had metal on the bonnet release instead of plastic like mine.
Do you know if I would be able to get a bf fuse box and swap em over easily or is it a bitch of a job?
Fuse box is pretty easy to do from what i remember. The only pain in the arse bit is getting the wire bit of the bonnet release to pull through. When removing it you will need to drop the wheel arch liner out makes the job a bit easier. If you have mud flaps you will have great troubles getting the clips out. You shouldn't have any troubles getting a fusebox. I am not 100% sure but i think BA/BF fuse boxes are the same
i didnt read the 7pm bit....so night should be fine for missing parades i guess....lol. :whistling:
*hopefully i can make it......all depends how sober i am from the night before
Edited by boiracer
Anzac day woollies is closed... so i wouldn't imagine a problem...
I'm doing up a pro/con list of FF vs FR. Anyone care to contribute? If I do it on my own I might be subconciously too bias.
What do you want to know?
What point of view are you looking at the question from? Driver? Manufacturer? Mechanical issues/reliability? Why no AWD being considered?
For example, a major pro of FF cars is the lower cost of production. This isn't much of a bonus to a driver however (unless you count purchase price into the enjoyment factor.)
In the end it comes down to your traction circle and the physical limits you can take your friction surfaces to (tyres).
Carroll Smith Has a fairly good entry level explanation of this in one of his books, tune to win I think is the one.
Dubstep fiends - about a year ago when I played CSS alot, there was a song that would come on and it had a part of summer heights high in it - "how is it ok for you to bully ben?" any ideas on song name?
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
