Erm... they usually go till around 4 or so... presumably will finish and then happy laps will start not long after.
They sell food there but it is crap and expensive. I usually buy it anyway though :P. You can bring your own if you want though. Suggest you bring a chair as well...
Didn't know if the canteen thingy would be open. I don't have a chair :(
drop past here on the way. I'll leave my fold up one outside. (I want it back though.)
I'd say a small hole in a radiator hose is a win for the club as far as damage goes. Much better than two cara going home on the back of tow trucks as happened last time :(
We'll have to coin the phrase
I've done a Boz
if any one of us busts anything to do with our cooling systems.... ;)
We'll have to coin the phrase "I've done a Boz" if any one of us busts anything to do with our cooling systems.... ;)
I did a Boz once:
Did an oil change on the chair. All the vitals are very healthy. Lovin it. :thumbsup:
WINNING.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
    • From memory it wasn't too hard to simply see which wire ran where when you plug that in. Unfortunately also from memory the OEM sender does not use the same configuration 99.9% of gauges run. So in other words if you connect the signal wire that was running to the OEM gauge to your DEFI gauge you might find your oil reads at 200C or some other incorrect value. I remember having the same line of thought and then running new wires/senders to match the gauges I have. The pinout is available in the R34 workshop manual.
    • Does anyone on here know which wire on the GTT triple gauge pod harness is for the oil temp gauge? my sensor works fine but I upgraded the gauges to DEFI advance. And if I can simply piggyback off the oem oil temp wire to the Defi oil temp sensor wire that would make life so much easier.
    • Even face her a wash now that’s it worth more than my house
    • This was what I was invisioning, or Pete cutting a beer can up and hose clamping it around the catch can! Ha ha ha
