I bozzed in my pants, I bozzed in my pants.........I opened a window and a breeze blew in.......I bozzed in my pants, I bozzed in my pants.....
bwahahahahahahaahahah :thumbsup:
getting to work this morning requird a stop and rewater, but new hose fitted and seems to be functioning finerofl.gif
must get better wheels and tyres for next time!!!!
also are there gonna be pics up somewhere?
Edited by KRECHR
@John: GPS says I was doing a max of 190 :(. I don't think I trust it.
Also, you owe us some pictures ;)
that reminds me. I should look at Boz's one once I toss the screen back in. I bet it says the same if not higher.
Don't think I got it much past 170 or so down the main straight, will be curious to see what I actually hit. Was too busy looking at the track to pay attention to my speedo.
we will know on wed morn.. (hit reset on it as well ;) )
I watched your speedo max out and the rpms keep climbing. That last run down the straight felt like 210 to me.
I found out I don't have speed limiter cut on my car after my speedo hit 180 but I doubt I hit quite as high as 200. Didn't feel as fast as the pintara.
Pictures soon bro.
Can't trust a factory speedo anything past 100. Can't trust my speedo at all, its reads about 12% high at the best of times.
I would however be surprised if I was doing less than 210 in the sprint sessions. That run I took you on, that was probably 180-190 odd.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
