Ahh, one of them big magic fuses that actually supplies 12V hey?
yep.
been working on/off it for the last two weeks whilst doing other work. I now have 3 full days on it to get the battery moved properly. toss two battery disconnects in place (one drops the alternator inside the car.) take out the AC wiring, rewire the heater,rear demister and fix a lot of electrical niggles in it. right now I'm doing 0 AWG body earths on it using double jacketed flame proof wiring on the lot.
its a fairly full on job and I'm documenting a lot of it o camera.
And here I was all along thinking it was a battery that did that.
Where can I get one of these fuses Chris?
yep.
Sounds like fun. Keen for photos.
ppfffttt... batteries are so 20th century. Magic fuses are where it's at :thumbsup:
He's ok. Sore neck and collar bone but no visible injuries.
He's in a neck brace and on the magic puffer.
Car is most likely a write off. If Jeremy allows it can post some pics later.
Bags went off.
He was going straight, little old lady was coming the other way. Somehow failed to see him and attempted to turn right, right in front of him.
Don't think he even got a chance to brake.
Forgot to say, little old lady is fine as well.
Didnt see her before she was taken to hospital, but the paramedic said she was fine.
I have Jeremy's blessing, so will post some pics when I get home, 4ish
if he gets it back that will allow him to fix the cefiro :)
but yes that is definitely a write off.
Would be a pretty big job. n/a ceffy would have 4 stud hubs so would probably need to swap all the brakes and hubs out as well.
In the second shot you can see the ass end of the corolla wagon that the old lady was driving
forgot to take any photos of that, but it was worse off, with the whole front end completely crumpled in, with the windscreen broken, and the pillars creased.
Not sure,
I was taking photos of the car when Jeremy was talking to the cops
I could be putting words in his mouth, but I think he didn't even have time to brake, so 60ish, and probably 20 odd k's that she was doing.
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
