Yeah he seems like a pretty likable guy.
1 year today mangs since I got my license back.
Are you fkn serious!? Wow that year has gone past scary fast.
Apparently there are no R31 right side handbrake cables in Australia and I have to order one from Japan :rant:
Anyone know around how much it would cost to get one made up at some place?
@Joel: Sounds like BS. HR31s use a different handbrake cable mechanism anyway.
Have a bit of a search on 31 club - i think theres some info on there somewhere on getting them custom made.
Also try rapeco, pretty sure they sold them last time I checked, but dearer than nissan :(.
RE: Redzomboobies, etc. I will comment when not at work...
he wants blue. std small nissan bulbs on the back ot it. send me a text 0407102839 and I will send you the rear of that cluster.
i see you got stuck in Geebung this morning...
I had a customer that saw the whole thing happen sitting at the barrier on Newman rd on his way to work...
Needless to say he didn't end up staying at work for long, he was violently ill...
Yeah. It significantly lowered my contempt for the little german weasel.
I saw an interview with him before the race on the bbc and yeah, he came across as allright.
In the podium press conferences though he's farkin annoying. And there's that f*cking finger... :devil:
lost any points?
Redzomboobies caused much fappage. I can has moar?
Def need moar redzomboobies!
look at the speedo.. they are not meant to go that fast.
I can make a speedo go that fast... on my bench.
I must have just missed all that traffic on the way in to work. Heard about it all when I got in. N.G. :(
traumatised I bet. wife works for QR and told me she was stuck at zillmere. thats how I found out.
    • This. The R34 handbrake icon DOES come up when the brake fluid level is low. You might be sitting right on that threshhold. I have been down this diagnosis path and this was the solution (and it was pretty much as full as your picture is to begin with).
    • Unfortunately the cavaet to that is that while any scan tool should be able to read the code, the workshop will need a consult plug to OBD socket adapter. You don't have a location on your profile, where are you based?
    • @Haggerty this is your red flag. In MAP based ECU's the Manifold pressure X RPM calculation is how the engine knows it is actually...running/going through ANY load. You are confusing the term 'base map' with your base VE/Fuel table. When most people say 'base map' they mean the stock entire tune shipped with the ECU, hopefully aimed at a specific car/setup to use as a base for beginning to tune your specific car. Haltech has a lot of documentation (or at least they used to, I expect it to be better now). Read it voraciously.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
