one of our long term employees is leaving today. I think once lunch time rolls around the booze will flow and the day will be over! :) so yes tfif
sounds like a perfect Friday at work to me! enjoy that
I have today and all of next week off cause we are quiet at work, it's easier to make a shop look busy with 2 qualified mechanics on holidays then doubling up on jobs
I nominate you to get me some brakes for the wedge, and sort out the engine mounts in the alfa :thumbsup:
same as me then. I took today off and for the whole day my shop/mobile has run 3 times. mechanic that is next door to me has teh same issue. shop to run with little work in it.
Well i have to be at work but i have done SFA today think the phone as rung 5 times for jobs no longer than 20mins pinch.gif
IS IT OVER YET!!!!! I WANT TO GO HOME!!!! Im getting a trend today tho. everyone has had enough. im going to go and drink a lot of alcohol
Edited by Kiwibob
Just got home from work :(
Be back there at 8 :(
Fail.
Wow. and i thought iworked long hours.
Raining horrible day. Dont want to be here.
And here is the killer.... We missed the delivery of my new phone yesterday and i cant get to the post office to pick them up till monday.
I knew i should of put the delivery address to work!!:(
Hey Martin, did they come from Ryan Dunn's car???
If so they will be in good condition, were hardly used...
Not sure if hilarious or in bad taste... Both?
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
