Here is your non work safe pick me up :-)
http://iwantpix.com/9291/angie-varona/
fark...I would hit that with Poland!
She has a funny thumb like Megan
You saw her thumb? Are you feeling ok Jez?
Morning All.
Can any of you samsung galaxy people answer a question i have of the battery?
Phone is truly awesome but the battery is, how do i put it, crap! i am lucky to get a full day out of it and im not using it all that much. Is there a fix or do i just put up with it?
Cheerz.
Morning All.
Cheerz.
Same here. I have fixed it by buying another charger for work and a car charger. And Ta Da, no more battery issues.
lol yea i think i will do that. i use the usb cord atm to charge it at work.
Make sure you don't have your wireless constantly turned on - This is a massive battery drain. Only turn it on when you plan on using it.
I onlyy turn it on when im at home and connected there. Otherwise it is off.
Dont get me wrong, it is an awesome phone and i am more than happy to put up with a short battery life but just wanted to make sure it was normal.
Get the battery doctor app, do a full cycle charge and bingo should last you the day no worries.
Mine stopped charging all together, off for a warranty fix for me!
stopped charging cause of water?????
I normally can get 2 days use from my galaxy S2 are you constantly using the net?
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
