So who else besides NRMA and the Suncorp owned companies (AAMI, Just Car, Shannons et al.) insures grey imports? Going to vote with my feet once this is all over and NRMA will only cover my car for $12k at a cost of $1300 a year.
http://www.dawes.com.au/
That's who I went through.
Thanks for the offers.
I am looking for something with legal thread
Car is a cop magnet and the religiously check my tyres for signs of hooning.
The fact I am rolling on triangles should have been hint enough that I can't afford the petrol to hoon
Cheers
Just going through the boost classifieds to find some stockies that hopefully somebody is discarding.
What are the specs of the above rims for the Leopard?
If I could, that would be great. don't really care how it looks :P
Will pm you later to arrange a journey up to the mysterious north to come pick them up
your welcome to them, i think they are kinda legal. not much on em, but above the markers from what i recall.
15x7 +20 wheel, 7.25kg per wheel, 56mm dish
15x8 +5, 4x100/4x114.3
16x8 +15, 4x114.3/5x114.3
16x9 +0, 4x114.3/5x114.3
16 x 9 +0...Do et!
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
