Its quite good again ;)
How old is the guy that bought John's 32?
Bloody hell. If i got a gts4 for 4000 bucks i wouldn't care if it cost another 4000 to repair.
Summoned for Jury Duty...
Work wants me to get out of it :domokun:
I'v done the Jury duty not long ago, didn't get any murder case so wasn't very interesting :D
Morning Mangs,
TFIF.
Yeah i think the level of interest will depend greatly on what kind of case(s) you get assigned to, if any.
Oh well, employer has sent a letter off asking for me to be excused, I don't much care if it works or not.
Mangs,
Short day today hooah. In head office at 2:30 for some presentation on the Wintergarden and beers :cheers: Can't find the motivation for anything else though.
hard to kill time on here on your own :(
new desk has freezing cold air con, yay! :D
You have an air conditioned desk...What will they think of next. :whistling:
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
