knock off time on fridays depends greatly on:
a) how much work there is to do
b) how many hours i've already clocked in the week
c) whether the project manager is here or not
Today the answers are:
a) Nothing
b) Enough by 12:30
c) He isn't
Hence, I will be leaving at 12:30 :)
Wish I could have finished at 11 or so instead... then I could watch f1 first practice
Dam, wish i'd thought of that...i finished at 10:30 this morning :woot:
Gave me time to get my priest fitted....... :wacko:
is that code for something?
I was trying to figure out if it was or whether this is something a church going man might have to do on the occasional afternoon
Edited by PWND
What happened to the job at Indooroopilly? Thought you were meant to be working on the renovations there.
Also, if you end up working on road projects I'm going to hold you personally responsible for every pothole I hit from now until eternity :P
good to see you guys got the joke :)
but Rhino has it correctly, its my new/old HKS exhaust! so i wont be rolling around in complete silence tomorrow
Fun times ahead this morning. Need to pack campsite away and it is raining. Beautiful.why does the rain God do this to me!
I feel ya...getting so sick of this weather.......freaking showers
nah. bit quiet today so I called it a day at 12 and went yard scouring for 31 bits.
Find any TIs?
+1
martin,
no. TBH hard to find any of them at all.
3 wreckers and the 3rd mainly had pintaras which works for me as I only needed trim bits.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
