I'm after anyone running a HKS GT-RS on an RB25DET, (genuine HKS kit, not a Garret equivalent) to post up their dyno graphs.
Specifically their boost graphs.
I'm running one on my car and have been for some time, but only recently 'finished' the package off with injectors and a Z32 AFM...
It made 253rwkw on 18psi, but boost isn't holding in the top end, which is why I'm after other's GT-RS graphs, as well as any similar experience with boost not holding, and how you overcame it if you did...
My car has all the supporting mods, with most mods being Jap brands and not cheap chinese copies.
Thanks in advance :)
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/
do you have an electronic boost controller? Honestly every dyno graph I've seen I always seem to see the boost pressure starting to drop off at the top end mine included. My tuner said that it's very common for skylines. I'm sure someone will disagree and probably has more useful advice.
How much is the boost dropping off and how quickly ? Post up your dyno graph if you have it handy
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4481180
I am interested in this as mine is also dropping off albeit on GTSS on a 26, but the same question ponders, I am going to replace the EVC6 to see if it is defective failing which I will wind up the HKS actuators to set them at 14 psi (currently at 11) so the evc only has to hold 4 psi above the actuator pressure rather than 7.
I hit and about 18ish for say 1,000 rpm and then as with the above, it tapers off a couple of psi down to low 16's.
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4481941
I have the same problem as well, it peaks at like 19psi then falls to like 17psi, no matter how much I stuff around with the duty cycle settings.
I thought my BOV was leaky, so I put a rubber sheet between the stock BOV & the cross over pipe, no difference. I thought it was the actuator, but after seeing dyno graphs, it seems to be the norm.
https://www.sau.com.au/forums/topic/261410-hks-gt-rs/#findComment-4482166
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
