i think the motorman trick did work...
year 2000,i trashed a brand new car that has not seen 1000 km.(brand new sister's car)
taking it to the rev line every time in every gear.
and now the engine is still running perfectly and without any rebuilt since the day we bought it.
back here in my hometown, usually the mechanics ask us to run in with mineral oil for 500km's and then another change using mineral oil for another 2000 km's. only after that, returning back to use synthetic oil.
but we didnt opened the engine to check if the technique really worked.:)
  • Replies 45
Oh very interesting to hear, I've not heard of any engine builders around here using that method, especially with synthetic and not a mineral oil, I wasn't sure if it was a tried and true thing or one of those things that was done by one or two people and then argued on the forum as an opinion point!
Fair enough to go on what your builder says, most of my mates use EDGE and i've seen an RB30 with just under 500 000km unopened, with Castrol synthetics used nearly its entire life (mind you thats also a motor which wasn't thrashed). Thought that it may have had a detrimental effect when the car's being driven to its potential, due to breakdown of stabilising additives in the oil (due to it apparently being a hydrocrack derivative and not a 'true', synthetic.
But then over how many km's? (this poses an interesting question)
If your swaping every 5,000-8,000km's does it breakdown enough? Or is that only over longer service intervals and so on.
There are lots of variables if you wanna dig into it all IMO
Well from rereading a couple of pages in the oil thread, I'm guessing that visual signs such as fuel dilution and consumption of oil (you'd be hoping that would be minimal in a new motor though!), and if you're anal about it, a used oil analysis?
I don't know of anyone who changes their oil over 5000km either, I was of the understanding that only newer engines such as the LS family of motors could go for 10000 vs 5000km changes.
I think anyone asking for above average/high performance of a motor well above its factory specification should be changing oil frequently.
I change mine after every race meeting....cheap insurance. Actually its not that cheap $250 a change...but better than a costly rebuild.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
