Hi man
All the parts i have are for r32 gtr i am wrecking a whole car (yes my baby)but it is ok as i bought another one last weekend in melbourne.
so are u after
2x gaurds,2x headlights,radiator,intercooler core,air con rad,air con fan,radiator support panel,frontbar with lip.
is this what you need?
Edited by NISSANGTS
atm will need front rio bar, radiator and headlights atm.
radiator support panel prob, will need that further inspected.
air con dont give 2 shits about lol, rip that shit out.
what size front mount you got? my old one was 600x300 from memory, my existing piping is fine.
wont need guards as they are fine and weren't damaged.
front bar is a possibility at this stage, depends if i can fix mine up.
Hi Funz
pair of headlights
radiator
front reo
gtr genuine intercooler
everything in good condition and i will deliver tas wide no charge
$1100.00
Hi Funz
pair of headlights
radiator
front reo
$1100.00
cheers mate, atm will prob take following:
headlights
radiator (gtr one is exact same as gtst?)
front reo
have sorted FMIC which is exact same size as my old one.
Radiator support panel just appears to be pushed back where bonnet latch is so can prob be pulled back out, anyone able to do this at all?
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
