Condensate in catch cans is not surprising, quite common.
Easy thing to do is get a clean oil pan, remove the drain plug and see exactly how much oil comes out and what is in the oil.
Get some fresh Castrol Edge 10W60 and throw 4.5L in there. Turn the engine over, make sure there are no noises, you have strong oil pressure etc then shut the engine down.
Then go get new clear hose for your catch can, remove and clean the catch can then re-install with new clear hose.
Then go do your normal day to day driving but dont thrash it. Just drive the thing normally under some load and see what the oil pressure is doing, you lines to the catch can and the level of oil n the sump and catch can.
Dont panic, just be methodical about what it is you are doing. Odds are the miss is fine and not related. Lazy coil pack, faulty igniter or perhaps normal. My thing has a very small miss at idle its no biggie.
But i have never lost a sump of oil before.
Real silly question but when checing the oil were yo doing it in good light. I mean are you sure the dip stick wa going all the way in up to its shoulder when you were checkign it? Either way dumping the oil will soon confirm how much is in there
i just topped it up today with roughly about 2.5lt worth of oil so its gone through that amount in about 4500kms
but i have driven it fairly hard???
what do you guys think?
the mechanic said he will do a leak down test to show me but he said he is not worried at all
he said "dont worry you have forgies and everything"
he said he was more worried about the last time i brought it to him.....
cause my fuel reg shit itself he put it on the dyno and it was leaning out
he backed it off straight away and fixed it but he said hopefully it will be all sweet???
i wish i knew more about this crap mechanics is not my specialty
whats this about the dipstick????
should i get a longer one or is that some joke???
cause its not so funny when you just spent 15k on mostly the engine
blow by on a street car should be nearly zero, the bigger the hp the bigger the ring gap etc so some blow by is inevitable but on a streeter it should not breath.
if you do a lot of stop start driving condesation is also inevitable in the catch can.
Edited by URAS
I assume that your rebuild included forged pistons? If this is the case it is quite normal to use/burn more oil than a standard RB20.
Although this also means you need to check our oil level regularly too. At least once a week or whenever you fill up at the station and top up accordingly.
Sounds like you should be fine, but as others have suggested, get a compression test done, for piece of mind.
Good Luck mate.
Edited by VSPEC-Boy
thanks guys it probably is nothing hopefully..........
and yeah roy i did check it with a flood light on in my garage a few times even burnt my arm on the floody
the miss in my car is intermittent it sort of happens on second startup when car is warm
sometimes on first start when car is warm
but sometimes not at all??
well the car is going back to the mechanic anyway on tuesday/wednesday he finally got my wastegate spring
and now he can finish off my tune
and fix the rest of the problems now until then i suppose ill just keep praying heaps and checking oil
if this motor blows im buying a stock V8 even though most guys on here will hate me for saying it
as a stock car the power and low down torque is good im sick of head aches when you got your own house money is hard to come by just to keep the toy running
i love turbo's but yeah shit does go wrong alot and often
but i must admit i love the look on a comi drivers face when you fly past him partly sideways in a drag
and before he has tried to race you he's thinking hahahaha its an r32 ill chomp him easy
i wanna get a sticker on the back of my car saying.
"YEAH AND ITS ONLY A 2 LITRE"
if it aint been checked for oil, or been maintained - then of course there is !!
Again, nothing to do with it if the motor is build right.
Maintained or not isn't the issue here far as I see it. Simply because you don't mince 2.5ltrs of oil on a very fresh motor if its put together right
That's not to say the turbo isn't stuffed and letting oil pass of course.
You could also look @ a crack somewhere, but there is no oil in the water, so that cant be it.
Only other option is it wasn't filled right @ last service... and I would cry if that was the case because running around 2.5ltrs down for a reasonable set of kms (more than out the workshop door) isnt good
yep you have it spot on there bud....
its not like i havent maintained it i just didnt think it would be that low after 4500km
when in the first 5000km it did it seemed to be fine everytime i checked it
anyway it never lost comlete compression lowest it was running was 2kg per m2
but that was enough to have no oil on the end of the dipstick
i always thought if it was that low the oil light would come on anyhow obviously i was wrong and now i know this
I could have had a RB26 built with big-brand everything for that amount of money...
Yet you chose to blow 15k on a RB20?!
So the mechanic put it on the dyno when you took it back and it was leaning out straight away with a bad reg yes?
and prior to this you where driving the car pretty hard?
That's not a particularly good thing, especially on a new build. I would be very suprised if it has not sustained some sort of damage, misfire is probably caused by burnt plugs running on poor afr. Did he replace the plugs after the next run with the reg issue fixed?
As others have mentioned I would be doing a leak down test straight away. I thought rb30 twin cam conv first too when you mentioned nothing on the dipstick lol.
just chucking 2.5 litres of oil in there is a bad idea and a waste of time and money. and it tells you nothing.
do it properly and actually discover if there is a problem. troy has told you how to do it. get a clean oil drip tray and drain ALL the oil. measure how much comes out, and what state it's in. then give it a nice 4.5l of new oil and a new filter. and do what he said about cleaning the catch tank and lines and using a clear line from the breathers to the can. why ask people here for advice if you don't plan on taking it?
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
