Hi all,
I'm just not used to this level of tech.
I'd like to reset my ECU but am not 100%
on the location of the battery.
IE when i open the bonnet I'm pretty certain its the black boc where a bunch of fuses seem to be just behid the window washer container.
I'm assuming that I would just disconnect both the red terminals on the side closest to the engine and that would disconnect the battery?
Please pity and help the skyline noob :uh-huh:
https://www.sau.com.au/forums/topic/26203-just-bought-r33-wheres-my-battery/
  • Replies 41
when you disconnect the battery, I would recommend you only take off the negative lead (black one with a "-" on the battery). I've heard that sometimes if you take the positive line off, and have bad connections somewhere in the car, then reconnect it it can blow fuses and even more important things like stereo, ECU, etc...
Just a suggestion, could be wrong...
I see the question "where's the battery?" and i think to myself.....
WHAT THE F^%K???????????
Mate....if you dont know where a battery is.....just give up now. Don't even bother attempting to drive that thing, coz it ain't for you.
There's your answer to where the battery is.
yeah that's harsh.
on another note, the battery in the back is a hinderance and i presume is only cos they couldn't fit it in the front. because the battery is in the back, you can't fold down the rear seats like in an S15 (or in pretty much any other given car) which really kills the ability to move anything large.
Hey dude,
unless u can honestly say u know of every nut and bolt in a skyline, dont go ard blasting others abt what they dont know.
Im pretty sure you wouldnt like such a reply if u posted a question abt sumthing u didnt know either.....
Don't be a tool, thanks for stopping by don't let the door hit your ass on the way out...
Well done Squizz, couldn't have said it better myself...
On another note:
The reason for only disconnecting the negative terminal is because if a spark does occur when you are reconnecting (due to some sort of fault discharge), the spark will occur on the ground side of devices (eg ecu), not on the positive.
This means that a discharge will flow from the device to a solid earth as opposed to a positive terminal disconnection where the fault occurs from the + terminal through the device.
Hope this makes sense, I read that somewhere...
Thanks for the info Baboon.
Not sure about any differences yet. After I first start my car is goes to about 1200rpm then settles itself down, even when hot outside. I think this is normal though.
I also notice that when the car is idling it seems to ossilate the revs till it finds a nice idle ie round 700rpm. Mostly the first time you stop at lights for eg.
I have noticed that I drove from Chermside (Northside Bris) to Lismore (NE NSW) on about 1/2 tank - I thought that was pretty good.
As far as i can tell the engine is in nice tune the engine is quiet, no leaks and the exhaust is a nice black. The car seems to rev out freely with no flat spots noticeable. Although I havent taken it to its limit yet - been wet in Bris lately I dont wanna kiss a telegraph pole...
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
