posting this for a mate from Patrol4x4.com
Hey guys, woke up instantly to the sound of my Jeep being started and sped off! I live in Broadview, S.A. Headed towards Regency Rd.
Most have seen pictures, but its a 96 White XJ, Faily Stock, Stock Rims Painted Black. Hayman Reese Tyre Carrier. Tube Front Bar with Warn Tabor 9k. Big MOPAR Sticker on the rear window. Southern Cross Stars on Either side Window Along with a Sticker for the Day my mate passed away reading "RIP Trent Bond 3/8/88 - 13/9/08". Has about a 2" lift with OME Nitro Charger Shocks. Windows are tinted.
So this message mainly goes out too Tonto, HillsJeep, JohnJK, Woody, and All the other Adelaide Members..
If you See if, please report it and pursue if possible..
Maybe 2k in vehicle value, but well over 5-6k in stuff inside!
Cheers
John Sincovich
0403 179 043
https://www.sau.com.au/forums/topic/262063-stolen-car/
FOUND
Vehical was recovered! @ 7pm 23/3/09
Found in a dodgy area about 5mins away from my place.
They have gone over the whole thing. Stereo, Amps, Tools Tow Ropes, Winch Remote. both Gps's and loads of other small gear. all up about 1000 or so dollars worth of stolen and damaged goods.
Vehical also has a major sag in the rear drivers side. sag of about 1-2inches.
I would like to thanks everyone for their support and help with this matter.
I am relieved but will still have that anger in me for a long time. But the bulk of car is there and thats the main thing. It is covered all over in black fingerprinting dust so a wash is in order and i will most likley do a complete tear down of the inside and start again.
If anyone is able to help me out with were to get new key barrels and ignition seing as they are rooted that would be great.
Thanks to everyone for assisting me.!
https://www.sau.com.au/forums/topic/262063-stolen-car/#findComment-4494386
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
