acumulators are not aloud in the combinded touring series but we are negotiating with the rule enforcers at the moment about possible oiling system improvements that need to be addressed.
At the end of the day if we can improve the system and it means Duncan is at every round then they should be all for it. More cars racing in their category the better.
The current rules are a bit of a joke when these are meant to be "race cars".
Our engine sealer has told me two other holdens from last weekend have also now been diagnosed with engine issues after the hour enduro. One finished one didn't. His going to be a busy boy sealing up fresh engines for next round!
  • Replies 161
Posted Images
Without 4wd you dont generate enough G's to move the oil in the sump :wub:
Hahahahaha :P
Seriously though good point, you've also got a high flowing oil pump. How big is the sump?
Duncan are you at least allowed to have a head return to sump?
no the rules are pretty simple. all motor standard except sump is free. Brad is working on some piece of art new sump to make the most of that. No oil returns. No enlarged oil galleries etc etc its all standard spec
hey there might be challenges keeping rbs together.....but the car still goes fine when it's running. I figure the best bet is a spare motor so I just picked up one today (thanks for posting it down Russ :))
One thing to remember though comparing this car to most.....it runs a minimum of 20min straight at full throttle 95% of the time, 5000 to 8000rpm. Or in the case of the enduro same for an hour. This puts a real strain on water temps, oil temps, oil itself. Not to mention at least 3 full standing starts per round to smash everything around as well.
Its much harder on the motor than 3 lap sprints or even 20 min track sessions - I don't have the option for a mid race cool down lap if things start heating up so this has to be OK to go 100% for all its time.
Thats something alot of people dont seem to realise. Considering its a stockish engine it makes it even harder to keep everything under control.
We'll build something thats just fits the guidlines and make sure every prevention we possible can use is used.
The new sump is pretty awesome with a swinging pick up and multi level baffles.
You know now we have a spare engine coming your never going to need it!
hey there might be challenges keeping rbs together.....but the car still goes fine when it's running. I figure the best bet is a spare motor so I just picked up one today (thanks for posting it down Russ >_<)
Reimax gears in N1 case?
Same sump i have with some more baffles (is brad can manage to fit anymore in there)?
No not using Reimax gears. Found something we consider better.
Totally different sump design to yours Steve. This one has a pick up that is free to move around the bottom of the sump with the oil. Its got a revised baffle set-up as well which is simlar to yours,
Has anyone trying machining a spline on the crank and getting a billet gear made with a internal spline? That would be much stronger than the square drive at the moment and with no sudden change in direction like the inside of the gear now there will be only very minimal stress raisers.
We get tricky stuff like that made up regularly at work might be worth a try if anyone wants to donate a damaged crank to trial on????
well thats the million $$$ question really Ryan.
Once you start pulling apart borken motors it's all guesswork. sure some guesses are more educated than others and there is some evidence to look at but there is a lot of assumptions as well. especially on the internet.....
I'm using anything. motul 4100, elf whatever in this motor since it was run in, and penzoil 20/50 to run it in. Lots of theories about which oil to run too. Either way I change it every weekend.
Well i look at it this way, oil pumps have been failing so until engines stop popping or they pop with intact pumps why not make them bigger and stronger then see if it breaks? Then get into cavitation, vibrations and oil flow issues then? I am no genius but wouldn’t you just try and stop the bits that are breaking breaking. hhhhmmm.
Are the drive gears the main part that have been failing?
Or maybe the crank is heating up and expanding at a different rate to the gear so the clearance is too tight at temp between the gear and the crank so the crank splits the gear??
Too much night shift must sleep. zzzzzzzzzzzzz
As you increase the strength of one part, you make another part the new "weakest link"
to try and stay within a reasonable budget, you can't keep chasing the weakest link untill they are all above your power/requirments, sometimes....
isnt that mptorsport in a nutshell?
"how fast can you afford to go"?
I understand what your getting at though, the law of diminishing returns does apply, guess it's all relative to your budget though.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
    • That's my life. Past-Duncan has a lot to answer for
