i know there is a few topics on it already but they are old and i was wondering if anyone has been running straight avgas without killing the engine,
i use to run my old civic on it, but it burn out all the exhaust valves, but doesnt the rb26 have sodium filled exhaust vales or something??
not too worried bout the o2 sensors as they're prob already dead
not doing it for performance gains, just coz i get get hold of a bit here and there
https://www.sau.com.au/forums/topic/262343-avgas/
Umm, don't run it straight, best to mix with petrol 50:50, then ignition timing can be advanced (tuned to suit of course).
Don't run a cat converter, it kills them too.
It's not street legal....
That's all we have found.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4493798
a few of the boys at work mix it 50/50 and throw in in their motorbikes, saying that people usually take it from the slops tank, so make sure you drain for water content before adding to your tank.
it does require a tune to run properly, i stay clear of it personally unless you can guarantee a sufficient supply to mix half half all the time and tune to suit.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494585
Yes it will destroy a cat. It's leaded and it clogs up the cat. Makes it overheat to the point of glowing red and destroys it. I've seen it happen.
Dearlove, you might want to look into water/meth injection as a cheap option for the net effect of higher octane gas. Is it something you want to run all the time or just for track nights? If just track nights, you could also make some of your own high octane brew with something like tolulene (sp?) of xylene. Has the effect of taking US R/M+2 93 octane gas up to around 98 octane. What do you guys have down there? Av gas is only like 106 or there abouts IIRC.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494751
lol 106? id b shitting the gear if i could get my hands on some of that...if its tuned on 98 then 106 is going to make fkn absolutely no diff other than protect ur engine slightly from det...waste of time... rather stick 100 shot up it then tune it on that crap...at least it would have some valuable effect
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4494815
Because it contains lead, it is illegal to use it in a car complied to run unleaded. It will kill the O2 sensors, and the cat. (and de-catting is also illegal).
Before you get caught with it in the fuel tank, make sure you have a very good relationship with your local bank manager.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4495296
It doesn't kill 02 sensors - we have an XR6T that has covered thousands of kilometers on avgas without destroying anything - mind you it doesn't have a cat. And as for red exhuast thats crap. It leaves a white residue in the exhuast system thats why it makes reading plugs more difficult too - as they appear alot whiter ie- hotter than what they actually are.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496177
Gee maybe they painted it red then. my mistake
i just mentioned it because a friend of mine run it in his Supra for a while and the inside of the tip on his cannon muffler went red.
I love SAU. Its the one place to go when you want to make someone get all uptight.
Keep it up.
Edited by gotRICE?
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496379
HAHA, no im not stealing it.
i work in the aviation industry, thats all
and i know a bit bout the fuel,
it burns slower than 98 therefore increasing its detenation charateristics, and in turn it burns hotter, and killed my poor litle civic engine's valves
it doesnt make the exhaust go red but when running really rich i have seen it going 'sort of white' but mostly black
its got alot of lead in it, say the old leaded fuel for cars was like 0.05g of lead or something, avgas is about 6g (my numbers my be a little wrong) thats why they are trying to get rid of it just like in cars
it has a lower reid pressure, cant be bothered explaining, plus it doesnt matter if your running it in a car.
https://www.sau.com.au/forums/topic/262343-avgas/#findComment-4496670
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
