I just purchased the set of URAS NS-01 silver from Just Jap this morning!!! Cant wait for it to get here :down:
What size tyres are meant to go on there? I dont wanna put my speedo out of wack.....
Im guessing 255/40/17 ????
Yep...
Ringing around the tyre shops and they seem to recommend 245/40/17; but should i get 255/40/17 or would that be too wide?
Would 245 be wide enough to protect my rim from gutter rash?
Yep...
Do not drive into gutters and you will have no rash. Nor will you damage the sidewalls of your tyres, thereby ruining them. 255 will fit on a 9" but you need to figure out rolling circumferances too.
Speaking to the guy at TTF he rekons i go 255/40 as its the same total diameter of my original 32GTR rims of 205/55/16....
...so its booked in tomorrow for a new set of Hankook K104's :laugh:
I'll post a pic when i fit them on :P
Looks nice buddy!
URAS NS-01 (Nismo LMGT4 copies) LMAO! Nah just kidding they looks awesome.
So whats the size of the rear tyres you ended up putting on?
Its always good to have the wide tyres at the rear as you will gain a bit more traction.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
