Hey guys i just brought a r32 gts4 and befor i could even get it into my name and get it insured it got stolen. im pretty shatterd.
if you hear or see anything please contact me.
here are a few pics.
it has a pretty unique intercooler on it (pictures below), i painted my logo on it, and some pretty unique paint as well, its black with a gold rainbow flake through it.
so if you see any of these parts up for sale please contact me.
At the time of the theft, did the previous owner...
i) still have it insured himself and
ii) had not banked your $$ ?
You know what I'm getting at eh?
Probably the horse has bolted imho
bad luck mate, i would think it was the old owner doing a dodgy, for someone to take wind u have a skyline and then plan to steal it would take a while
whereas the owner knew all the details he needed, and prob had a spare key he didnt tell u about.
I would sus the old owner out, never know u might see it at his house one time, its a possibility
horrible to hear mate, hope u find it!
so it was outside your house, does it have any aftermarket alarms? did you hear anything? any alarms? if not then that does sound a bit dodge...
now now dont go pointing the fingure at the previous owners.
sorry about the bad news mate. but try calling the previous owner and see if he still has insurance on it. if not best let the cops try finding the car.
also word of advice when you ever purchase the car, evem if its not in your name call an insurance company up and take out a cover letter incase something like this ever happens to someoen else. atlease that way your ass is saved from losing out your newly purchased car and your hard earned cash.
again sorry to hear but will keep an eye out.
One more thing...
Are there any usable parts that would sell on the SAU F/S section and you'd be able to identify them by markings?
Our family is in the process of Data Dot our Skylines atm
yea they are the same plates, as for any parts with markings ummm well i guess any of the parts on the outside are pretty unique as the colour is black with a gold/subtle rainbow flake through it, so if any panels with this colour come up that might be a dead give away. thanks for the responce guys! yea its sucks hard as i was saving for quite a wile and now i have to start all over again :laugh:
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
