  • Replies 69
hr30 is 2dr yes? and dr30 is 4dr?
HR30 is a 4 door at least mine is
also you might not have to upgrade the brakes if it is a HR30 as they came with a l20 et 6 cyl turbo engine
aussie MR30 came with non turbo l24 or l28
i have R30 workshop maual if you ever wan to look through it
sorr it aint for sale lol i need it for my HR30
Edited by gazza750
sweet as gazza that would be awesome as im goin to do somethings with the car on thursday and im planning my first lot off stuff to do with it and yeh that manual would be bloody awesome to look at! If not ill just have to source one out!
Yeh cheers bois with the info on the 30, love the fact that its actually a 30 cos ive got a few parts on the car that are 31 and now i no they interchange with everything easly afta looking at everything that it hasnt been customized makes it even betta!
check out this part of the forum http://www.skylinesaustralia.com/forums/Cl...ylines-f77.html
lot of info on dr/hr30.
you will find lots of parts can be interchange from r31, if i remember right you can also uses the brakes from a r32/33 if you do a 5 stud conversion.
pretty sure sr20 fit nicely into dr30/hr30
ive done the whole thread on the sr20 conversion it was my first thought but dont have that sort of money for it!
One thing i no of is that i would neva go r32 brakes as i have seen a mate ditch it with stock brakes and a stock engine on his r32 gtst.
And if i was to go brake upgrade with 5 stud conversion id be lookin at the r34s and thatll be min bout 2gs and i dont have that yet so im leavin it as is for now, until i get some real big money behind me
you don't need to go 5 stud for 32/33 brakes, you can get blank rotors drilled to 4x114.3
noobz, you could bin a car with big brembo's, it depends what your doing at the time. 32 brakes will be an improvement over what you have now.
lol yeh bois lol
neways i was actually already thinkin bout the 25 lata but didnt no if it was a good choice between that and the sr20 (i no a guy usin a sr20det in a torana thats runnin 8s)
But yeh i might even later wen i save the money for it upgrade the rear axle to a 34 so i have the brembos and the betta diff and stabelisors!!!
But yeh its gona be atleast a 2 year build to make it perfect and running how we wont it so yeh gona be awesome!!!
It has no engine atm that y if u look at the front pic closely, its raised bout 2"s...
neways triston man if u wont ill pm u the list of stage mods im doin to make it more interesting and show u wont im up to at that time hehehe
do you know what engine the car came with std?
If it was an fj20, i would be looking at putting an sr20 in it or another fj20.
fj20 are bullet proof, if looked after. Not sure if the 20/25 box will fit without modding the tunnel.
what do you plan to do with the car? quick street car? track warrior? dyno queen? drag car? etc etc
well today im going to look at and get pics of the rb20 that ive sourced out, so im gona be gettin that dropped in.
Well i have major things for this, not much of a dyno king, but itll be there.
its gona be build for a quick street car, show car, SPL car, and just a couple runs down the drags just to see portenial times...
But yeh goin bak to see the car today as well as checkin out the engine so expect a few more pics up tonite!!!
cheap power is to turbo a na rb30. $300 motor, $1000 turbo converson, cooler kit $500 way under budget and will eat ANY 20. and last longer.
meh my 2 cents, i have built plenty of turbo 31s with 20s and 30s always had stock brakes with good pads. they are fine.
some people go way over board, unless you are doing stupid speed in busy traffic.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
