ive got an r33 gts-t, stock suspension/height and all that. ill maybe lower the rear a bit in the future, front scrapes enough as it is. im thinking of buying these rims, will they fit without touching the suspension, will they scrub at all ?
rims are 18" racing harts
18x8 +35, 235/35/18 8"
18x9 +38, 265/35/18 9"
https://www.sau.com.au/forums/topic/263040-will-these-rims-fit-on-my-car/
i had 275 on a 17x9"+38 without rubbing on a lowered 33
see that makes no sense to me, either u have a drag car and u run 15's or u run circuit when ud run a 245 slick or 255 max. i dont see any use with a 275 on a 17x9.
Those mild specs will not foul guards or suspension on a 33. The only thing you will need to be concerned about is whether or not they will clear the 33 front calipers. Only sure way to find out is a test fit or if you know what disk type they are eg: standard, low, hi. Alternatively you can try and find out what car they were fitted on before and take a guess.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
