hey guys...
i have now bought all the goodies i need to make some serious power but i'm still running the standard clutch...
now I know I definetely need to upgrade it at some stage... but its actually fairly new so I was wondering if it could cope with roughly 275rwkw...
What would it be like to drive everyday? and what would happen when I take the car to the drags with the shitty clutch?
Basically what i'm asking is if I can keep using the standard clutch (with 275rwkw) until it starts to wear out or do i need to change it even before I think about putting the new turbo, pfc, injectors etc in...
A decent clutch would only set me back around $500 + install so its not a big deal of cash but i just dont want to throw away my current clutch if it could be used to handle that kind of power...
Just to let you know the car is a series 1 R33 GTS-T
Cheers
Edited by usmair
had a jim berry clutch in my r33 that made 285kw, cost $1300 plus installation
ur better off gettin a good clutch to start off with, coz i had an exedy heavy duty sports clutch (bout $700 i think it was) in it before i got the jim berry one and it lasted 3 launches at the drags before it shat itself
Edited by UWISSH!
double the standard output and the standard clutch goes kaput;you can pretty much measure the life span of the standard clutch in minutes when you take it drag racing. get the best clutch you can afford so you dont have to change it when you increase your power later in the future.
My GTR runs a single pplate ceramic clutch, just been modded and tuned and now makes 308awkw, 1st dump and the clutch shit it self and slipped, so you can imagine what it would have done to a standard clutch. now im up for at least a twin plate. With that sort of power I would talk to someone in the know though before you make the selection. You can drive around with that power and a standard clutch, just done give it to hard a time, cause it wont last. (As I found out).
Goodluck
u will be absolutely fine mate. i drove mine and it was fine. just be mindful with it. in the end i only blew mine up when i did a burnout :cheers:. but other than that, dont be stupid and it should last for a little while
the standard clutch cant keep up with the std turbo and std mods, that is exhaust, intercooler, tune, more boost etc
so even at 180/190rwkw it will slip and eventually fail
the issue with the clutch (any) is they (when they fail) cant handle the torque from the engine
this usually happens when the engine is ramping up on boost, the most torque is typically made then
when it "fails" the engine free revs as its ramping on boost, so it goes 1500rpm, 2000rpm, then slips to 4000rpm
each time its slips its doing damage the flywheel and other components, so making it slip all the time is a bad thing
if you continue to drive with a slipping clitch youll need to machine the flywheel and possibly fix other busted shit
typically a good clutch will be at least $1000 for a mild GTST setup
i got a heavy duty clutch for $1200 for my 190rwkw GTST and its tough as nails
ive known a few guys go for sub $500 clutches with 200rwkw+ and they fry them
you get what you pay for and the clutch, being the single component connecting the engine & drivetrain
its essential that its prefect and strong to handle the load from it
its well known that sub $500 "300rkwkw" rated clutches are junk
remember, the killowatts mean nothing to a clutch, its the torque from the engine that frys it
if it was me and i was going for over 250rwkw
i would go for the nismo single plate clutch kit (it comes with a lightening flywheel)
failing that, i would go for a nismo twin plate
with the nismo cluthes they follow a premium price but you can be sure
it will fit correctly, mate up and be rated correctly driveability will be the same as std (ie easy and spot on)
if you go for a custom clutch etc you may find driveability sucks
ie: it stalls its ass off each time unless you ride it like a whore
or its mega springy (mega excessive centre sprung) so it bites really sharp
i have a HKS gd max twin plate and its the nicest clutch i have ever used... smooth take offs everytime and loves 7k dumps has never slipped at all that was with 265rwkw. was expensive but well worth every penny imo....
Going through this exact same dilemma right now.
My GTR puts out 276kw on 16psi and any time i had the boost set at 16psi it would literally just free rev.
I mainly drive it around on 12psi, but its even slipping on that now.
So decided to get a new clutch. I've spoken to a lot of people and was originally going to go with "$500, 300kw" clutch, but soon realised that it literally won't last.
I'm just chasing up some final details but looks like I'll be going for a NISMO twin plate. Used, but will have it rebuilt before it goes in. Much cheaper than new. This way, it might cost a bit more now, but at least I'll be doing it properly and more importantly once.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
