  • Replies 505
Posted Images
iirc , npo's fall under org.au , com.au requires an abn
another idea with what Damo said
love this and damo's first one they are great please print them off and bring to the meeting please :)
Also thanks sled xx
Thanx to all so far that are really keen to help me i intend to get this up running and working cant wait for next wednesday
Also thanks sled xx
if my idea goes according to plan ill be there with some high res versions for people to see ;)
thats some really good work there Mitch
i am with ruby on the sticker he likes lol...red blue and white
the boys in blue will be able to identify us properly :)
The one mitch posted just looks so damn hot tho
its good to have white separating the colors as red and blue are primary opposite colors
like the aussie american and french flags heh
-D
might not be a need to get www and domain hosting if christian allows us to have sa.skylinesaustralia.com as a CNAME with a subforum;)
-D
what about RUNVS?
what about it?
I like the first one. What would it look like if you replaced the "." (dot) with a "/" (forward slash) ?
That's obvious with his singling out Cara's plate.
Nothing wrong with RUNVS 2 ... Cara paid mtoro reg for it, she's entitled to whatever plate she wants.
What about UNVME 2?
Still complaining?
yes ruby, i do nvu :)
not til next january.
cant wait, mums making a cake shaped like skyline with runvs plates.
oh thanks so much ted, but my birthday isnt until june. but thankyou for your lovely consideration.
Now that I've seen both final options, I like either of them ... / or no /
I do like the idea of the blue SA at the end, sorta makes no need for the / now
Red white and blue. I reckon we stick with those Nissan colours :)
We're gunna have the coolest logo out! ;) Well done lads.
Bloody oath Bruce!
-D
i take one evening off to swear at the corolla and something awesome like this happens!!!
im definitely in, happy to help however i can :)
will do my best to be at villis on wed nite too (provided the rolla is going)
top idea kellie.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
