Drivein -fast N Furious 3.5or Whateva You Want To Call It
what night should we go? plz dont vote if you have no intensions of going
43 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 146
lol come on man or is he a common man ;) krishy
hire 'the last ride' that was a classic commo style street race movie. made by same ppl as fnf
u disapoint me nightcrawler melbourne trips come and go but this is a once in a lifetime event :)
Edited by Inline 6
ahh no not again....sorry Dan i mean "come on" and not common lol
Andrew as Dan said man...its a once in a life time event :) lol
bleh - we have 12 lads, 4 footy matches, Crown Casino for poker Sat night, Sunday Dim Sum breakfast and all the trimmings inbetween. Starting it off with lunch Friday on Gouger St somewhere, then golf at North Adelaide North Course before we fly out :)
You can see why I am not that cut up about missing the movie ;)
+1 sleep at work!
-1 for sleeping at work when i cant...i work in retail, i need a change :P
Well, i have just found out that we are not going to be open on the Saturday because of ANZAC Day - apparently we are to big to be open - so legally we need to be shut or something.
So, ill be there as long as i get my car back before then - having some paint work done.
bleh - we have 12 lads, 4 footy matches, Crown Casino for poker Sat night, Sunday Dim Sum breakfast and all the trimmings inbetween. Starting it off with lunch Friday on Gouger St somewhere, then golf at North Adelaide North Course before we fly out :P
You can see why I am not that cut up about missing the movie :P
Damn Andrew
Can i tag along too :D
saw it last night at the drive in, took Amber aswel she slept through most of it haha. but omg Paul Walker mmm, i'd pay to see it again just for him lol
i thought it was a good movie, they make a good team :thumbsup:
I don't think I will be Roadtripping this weekend, so I think I'll be able to come. Can I watch it in someone else's car so I don't have to embarass myself?
Edited by Normsta
im sure someone can help you out normsta, just wont be me cause i dont trust you alone in the dark :woot: you look scary with that cam
ok this just in official time has been set, race to witch dr on before but im not keen on that.
Friday 24th 9.15pm
now the big question who's still keen, i know a few of you already seen it and have thus given up on drive in plan.
also forecast is for rain but i would imagine its light rain if any.
so i shall do the jerry maguire and ask who's with me :D im not fussed either way ill go see it in a cinema if no one's game.
Edited by Inline 6
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
