Galston to Gosford Cruise 8:30pm 17/10/2003 (Formerly Midnight cruise - Friday 17th)
  • Replies 161
alrighty then..................
if ure coming up to gossie i suggest terrigal they have food places open reasonably l8 plus a 24hr bakery.......... oh and there is a decent amount of carpark
plus if its a fri nite the cops wont be out as much cause the big nite up here is thursday
the pizza thing is easy cos as soon as i get tired i can piss off home. but this will be a better drive, i'll just cruise until i feel a need to make tracks. no excuses, I'm there :rofl:
History has shown that Friday night & Pizza at the beach on Terrigal has ended with cops :(
Depending on the number of people is Pizza at Gossie Station do-able ? Seems to attract much less cop attention than the carpark at Terrigal ...
I might have to be in for this, I have never come out on a skyline cruise before and would love to get some piccies. I will head hom from work then back to thornleigh(I work just off pennant hills road. City view Rd)
catch you guys then
mark
I've been on the last 2 Terrigal runs and never even seen a cop let had trouble from cops (and we were parked 100m from a cop shop).
catch you guys then
mark
Thats like 5mins from me!! How come i've never seen your car in the area? :(
Come cruising everyoneee!!! its gonna be fun! and a chance for us all to catch up :)
Originally posted by Moanie
Come on tosh!  do your thing! :) start a 'who is coming' list :(
and how long do you guys reckon the whole cruise will be?!
it's your cruise Mona.... I'm sure you can manage to do it
okies...please check the first post as i've updated it with a list of whose coming and the maybes....
Let me know if i need to make changes....or if you're intested in coming along...
We will be leaving Thornleigh Maccacs at 8:30 (i promise i won't be late!!) so try not to be late...i don't have alot of your numbers so not sure how it'll work if you are running late and still want to come along....
I will definatly be there. I haven't been out with you guys so can't miss this one.
I don't drive out of work during the day often. walk to the nearest shops and stuff. our carpark is F#$ed, takes 10 mins to get out of it cause you get parked in all the time.
Well i haven't been on one of your cruises before, blitz keeps telling me that i should come along, but i will need to call blitz to see where you are at around midnight, but will love to join the next cruise for sure.
Originally posted by Nismodified
CB radio to tell everyone how far behind i am during the cruise (wont be in use for long as its only got a 3km range)
Don't laugh that happened to me last time. Whats even funnier is within 3km of leaving Thornleigh I was already out of range going thru Galston :D
Taking a wrong turn and not having good brakes doesn't help haha :) I didn't catchup until about 20mins later.
/me removes his speed limiter :bahaha:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
