I got my R33 Auto tuned with specs below apart from the VG30 rear,
My Question is.. should I see more power once I put the Vipec on and retune?
My goal once fitted and tuned is 250rwkw(that would be around the 275-280 if it was manual so thats about all for a stock motor) and quicker spoolup and midrange.
Are these realistic expectations?
Dave
https://www.sau.com.au/forums/topic/264263-life-after-vipec/
do you mean going from one ECU type to another?
then if thats your question, no as the ECU doesn't make power
the state of the tune, so going from a remap / PFC / HKS etc to Vipec wont make any difference in power
and if it does, your old ECU wasnt tuned properly
if you mean from stock ecu to Vipec then yes, youll make heaps more power (everywhere)
For some reason its gone out of tune, dunno why, Ive been told that the stock computer still has too much control and a standalone would get longer lasting results.
It now pings on high boost(15psi) and blows black smoke out the pipe most of the time, and is slowly getting worse, Have been running on low boost(10psi) for months now.
I realise the change of ECU wont give me a better HP figure but thought the bigger housing and a bit more boost on a standalone ECU with a good tune might do it.
Also.. always runs Vortex98 and was slowly getting worse even before changing the rear housing.
Edited by Turbo Dave
Another question is what type of cat are you running?
i had an xforce on my car for 6 months before it failed and my car was knocking all over the place. Chinese = bad.
Im not sure if everyone will agree with me but id say you should get a good after market fuel pump at those power levels.
Edited by silverr34gtt
2 guys in Sydney that i know running the same hiflow but with stock housings are making 280rwkw@20psi on their RB25's.
If I can get somewhere around that I will be stoked.
If i dont get the result from the hiflow what would be the next stepup from the hiflow?
Something in the 300-350rwkw region but with minimal lagg so as not to suffer too much with the auto?
I plan on building a forged motor in the future to run a bit bigger setup but wanna max out what I have at the moment!
HKS 3037 Pro S running E85 will do the job quite nicely.
Edited by RB25DETS2
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
