Has anyone seen this car?
http://www.drive.com.au/used-cars/NISSAN/S...433705&pt=1
I saw it today its on parramatta rd homebush across the road from the honda dealership.
I just want to know if anyones seen it and can comment on its condition because i saw it today and really liked it. its pretty cheap for a manual n besides having no leather and a bose system its got the brembos and the display, as well as a somewhat civilised bodykit lol.
Im pretty keen to go buy it but next time i go what should i look out for?
cheers.
https://www.sau.com.au/forums/topic/264334-thinking-of-buying-this/
Have you driven any V35's before or is this your first V?
Remember don't rush in, keep shopping around. Drive a few of them even if you can't afford the one your driving at least you'll have a better idea.
Best idea would be take someone with you who has a V35.
Post up a topic and see if some near you can come with you to have a look :wacko: Everybody is nice here :)
yer ive gone and seen it in person and it seemed pretty clean.
yer its going to be my first V so i have limited knowledge of what to look for besides different shades in the colour and all the panels lining up.
I wanted to check all the electronics such as the power windows n stuff but flat battery.
wat else shuld i be looking for?
brake pads or brake rotors condition, all lights working (specially the footwells or door step lights), underbody condition (scrapes and etc), headlights or fog lights housing (there could be a crack as its a common issues with 03's), and test the door lock with the remote couple of times when you are inside the car and observe.
thats just for me, you can probably get a discount if anything..
ogz got everythin pretty much...
main things i would say are windows, central locking, all lights work, check for brake squel, listen for knocking sound outta rear axle, mm thaz all i can think of atm.. but like any car u buy jus giv it a thorough once over... n dont be afraid to haggle or get them to throw in extras, its a buyers market :D
main things i would say are windows, central locking, all lights work, check for brake squel, listen for knocking sound outta rear axle, mm thaz all i can think of atm.. but like any car u buy jus giv it a thorough once over... n dont be afraid to haggle or get them to throw in extras, its a buyers market :thumbsup:
My only comment would be that if the dealer can not add more than 2 photo's and very little writing on the Website then he really hasn't got a clue.
Would of thought he could have supplied a bit more detail...
Other than that... all the advice has been good, all stuff that all cars should be checked for.
Additionally, listen to V35_Paul and shop around, get the feel for a few, drive them all and do not buy the first you see.
yer ive been in a few but never driven any becuase im not that confident in manual. ive been practicing in my mates civic Type R but yerh still not confident enough.
Also the last one i checked out the guy told me its common for the brembos to squeak because of the ceramic material but it goes away once it warms up. is this true?
but thanks for the advice!
hmmm, yeah check over everything, tyres, brakes, lights, also, you have to take it for a drive, i never buy a car without driving it, if you dont drive it you wont hear or feel alot of things, obviously turn the radio off, but when driving let go of the steering wheel, does the car still drive staight or does it turn? listen out for any noises, may be clonks (which is normally suspension) or other things, you will know if it doesnt sound right,
if the guy said the brakes arnt noisey when hot, then take it for a big drive, warm them up, make sure he isnt full of shit,
and defently check under the car, make sure the rails and stuff mounts what ever it might be doesnt have big dents etc....
or you could always get racq to do a inspection if your unsure,
Hope this helps
Hope this helps
For sure. get the RAC to do an inspection. it cost abit $200+ if i remember right. but they go over it with a fine toothed comb.
Take it for a long drive. Make sure you drive it and not the dealer drive it for you. I hate it went they do that "Wankers"
As for Brakes squeaking because of the ceramic material, I doubt that the V35 had that option so that would be a Salesperson without a clue, lying or just plain wrong!
Unless you buy a top of the line Porsche or similar, you will not get Ceramic Brakes.
Squeaking Brakes can be minor and easily fixed, scored or bent discs with cracks can not without a bit of cash thrown at it. Calipers that have worn or stuck seals are also a bit painful.
I think you may need to continue the research on the car itself and be confident with both your knowledge and your manual driving skills. Then you will see when a Salesperson is full of it.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
