  • Replies 250
Tell us how the car feels after. That's my next suspension mod :/ front n back sway bars + rear strut brace... than i just gotta replace some bushes with nolathane ones and I'm set.
handling > horsepower.
+1
Especially on tight courses or hill climbs. My mates dad gets 36.8sec up Collingrove Hill Climb in a dead stock new clio with better suspension. Guys in Porches cant usually match that. But the guy has had years of experience on the same track so i guess "experience > money" counts too!
Got my slotted RDA rotors and qfm a1rm pads in finally!!
Bedding in was sketchy but after a good 30min drive, then going for the brakes hard again :) MASSIVE difference... im afraid to push it past half way, it just locks up regardless of speed. Gonna take a bit of getting used to for smooth quick braking but daaaammmnnn!!! Highly recommended.
Steel braded lines + master cyl stopper are next up then braking setup is finished.
Oh btw, since its track talk here, anyone know where I can get a decent cross bar for the r33? Its the bar that goes behind front seats used to bolt up the racing harnesses on to..
http://features.evolutionm.net/article.php?id=55
Edited by SkyHi_33
im jealous, i still have my slightly warped discs from the BSM cruise..also, if any1 could help me, is it ok to have a video camera strapped in with the use of duct tape? i would like to get some footage from the dash and im not sure if its allowed or not, i just want to make sure. Ah im so keen for this...first time track-user...
I cant wait for this, took the Skyline for a drive today for the first time in ages. Sort of forgot just how much 420rwhp throws ya back in ya seat :D
Edited by DSTROY
my car is slowly getting there. Needs all the new belts on and water pump, New tyres and then a wheel alignment.
gonna be a busy week.
yeah, i had the belt, tensioners, waterpump, radiator, hose done recently and im glad i did. can breathe a little better :D
just need to get me new pads and rear slotted rotors and the n1 turbos and my gearbox fitted and ill be laffin
-D
Im changing my engine oil n coolant tomorrow.
Does someone know who can service my auto trans cheap this week? I'm really low on cash and don't have the room to do the trans at my house.
Also, anyone got a 3"- 3.5" cat lying around cheap? I got the dump pipe ready to go in but would like to do the cat at the same time.
Cant wait for this!!
yeah, i had the belt, tensioners, waterpump, radiator, hose done recently and im glad i did. can breathe a little better :P
-D
Ben the pads we put in had plenty of life left in them so should be OK for awhile unless they're not pulling you up like you'd like.
IMO, for your use, slotted rear rotors = waste of money.
the pads do have more life but they dont bite anywhere near as hard as the bendix, and i really hate that.
just going to get the rear rotors at the same time i get q1fm pads, less hassle in the long run imho - slotted on all 4 = sexy too
-D
I hope you have a auto trans cooler for your auto box, i wouldn't take a auto car to a track without one
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
