Ok, so finally got around to geting the car in for some work.
Picked it up yesterday afternoon, and so much better.
Unichip back in and tune. As well as water pump, timing belt full service the works.
now up to 141.8 AWKW at 0.75bar. Also the 4WD is working awesome
So much better, awesome to drive, now some suspension work and fuel pump next on the cards.
https://www.sau.com.au/forums/topic/264974-stagea-back-from-tune/
few small ones, turbo back 3 inch, cam gears, bigger cooler, tranny cooler, fuel pump which is on the way out apparently.
Boost module isn't working apparently so putting a new one in to try so just a bleed valve for now.
Laptop hooked up to the unichip and tuned through there i believe.
Hi RubyRS4, another option if it's a S2, is the Nistune - not a piggyback solution but basically a whole new computer (makes it fully programmable). Mine set me back just over a few hundred and that was including installation into my ECU (sent it away, got it express-posted back). Boostworx in Adelaide (just off South Road) handles them. Matt handles the type 4 board install (attn: Matt - [email protected]).
Edited by DaveB
I also just got my car back from a remap. Got the nistune board, the install itself and the remap done for $650. Now running at about 11psi and getting 163.9kw. The drive is sooo much better. Need a bigger dump pipe (still got stock), bigger injectors and a bigger turbo and that 163.9kw will become as slow as a snail, haha. But since it is my daily I'm in no rush to get it done, it'll just make my car more conspicuous and less expendable...
That's pretty good for a stocker! Just a bigger exhaust will give you a useful power increase and if you get the right one it won't be too noisy.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
